C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Maggie Front Blower belt help....
Old 09-11-2018, 02:20 PM
srm077
srm077's Avatar
Default Maggie Front Blower belt help....
Any tricks for replacing the front blower belt on a C6Z Maggie with a 10 rib conversion? Do I need to pull the front end off and remove the abs pump to get the belt on? There has to be a trick.
Old 09-19-2018, 09:34 AM
irok
irok's Avatar
Default this
you may be able to remove the 2 bolts in EBCM bracket that bolts it to sub frame to give you the clearance you need to install belt.I installed a 1/2" spacer in the bracket on mine to do belt changes with 8 rib power steering pulley on my A&A set up.could not change belt without spacer and top engine side bolt in bracket would contact ps pulley when braking
Quick Reply: Maggie Front Blower belt help....
