nitrous guys----LNC2000
putting together my nitrous setup and have everything bought up pretty much ( progressive controller, window switch, stand alone, etc) now just wanna get a striaght answer..i already have a msd two step on the car but do i need the lingefelter lnc2000?
the car is going straight to my tuner to do the tune. just wanna get a better understanding of exactly what the lingelfelter does.... from my understanding and what ive been told is thats so you can set the timing of the nitrous tune yourself if you dont go to a tuner....
so being that im getting tuned for it and have a two step box...do i really need it?
I'm planning on setting mine up with the tricker.. My car is SD though.. I feel that anyone in the past that has negative reviews on it with speed density, wasn't setting it up correctly in the tune..
You don't need anything if you have a way to flash back and forth between tunes. You can flash your nitrous tune and when you want to race on motor flash your NA tune.
you dont have to buy the lnc-2000 specifically ....there are several lingenfelter boxes that will pull timing.
i used a 10yr old lnc-002 2-step/timing retatd box that i found on ebay for 100 bucks......you just have to dig around. i was so close to using the iat tricker before i found the box thorugh, but only saw it on older cars on ls1 tech
anyhow, good luck
anyhow, good luck
