Missfire issue with my Nitrous ls3
Hey guys, I have a 09 Ls3 with a 100 shot, heads, cam, making 480whp without the bottle, I just got my bottle refilled and i raced my buddies car last night, we did about 4 pulls and the first 3 i had no issues, on the 4th pull, I switched it to 3rd gear and i could see that the afrs got to like 13.5, it started missing and cutting out and my check engine light started flashing. I didnt have my bottle pressure very high, it was at like 600ish, I have some Br7 spark plugs in there gapped at .33-35, any idea on what it might be?
tighten the gap to .25 and see what happens. I had a problem under boost where the engine started breaking up around 12 lbs of boost. tightened the plug gap and problem went away.
I think the plugs are ok, im gonna check them this week but I think it is too low of bottle pressure, my pressure was only at like 600ish so it sort of makes sense. I didnt turn the heater on at all so next time I will
Ill pull them all out this weekend and check them again, like i said though, this only happens sometimes, its not every time, the last it happened, i had 3 hard pulls on it and then it happened
thanks for all the help guys, I bought a nano system so I'm gonna hook that up for next year. It's been pretty cold here every day so I dont think I will use the nitrous anymore this year. I'll put some new plugs this winter and maybe even a fuel standalone cell and hopefully she rips next year.
Nano system is god-like in this cold weather. I run one. Keep the bottle cool and you won't have any issues. If you plan to run larger than a 150 shot, I would change the regulator in the HPA bottle to one of the new Ninja V2 regs with the ball valve instead of the needle valve. It flows more and will keep the pressure more consistent.
Yeah Im really excited about it, i am still missing the nano check valve so i am waiting for that and then its ready, next year should be fun
jayyyw (10-30-2018)
