C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
UPP T4's putting in work
Old 10-18-2018, 11:40 AM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
Default UPP T4's putting in work
As we go through the break-in process on this engine the numbers are starting to trickle in. Thus far we're up to 7psi with a respectable 878/796.
And it looks like there's still more to be made up top as the power isn't tapering back by red line. We're going to start increasing rev limit once we swap over to some 110 and higher boost.
Old 10-18-2018, 11:47 AM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
On our quest we did have to clip back the WG springs a couple times to try to get the boost back lower (so the boost controller could later increase it). And as you can see 9psi and 11.5 psi are no slouch either. And boost starts coming in ~2400 and full boost just after 4000. We had to cut the runs short as we just weren't comfortable with that boost on 91 yet, but you can see they were itching for 4 digits.
Old 10-18-2018, 02:31 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
Here's the vid.
Old 10-19-2018, 11:50 AM
camarokidz28
camarokidz28's Avatar
Nice! What's the engine setup?
Old 10-19-2018, 05:55 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
The bottom end was built by SAG performance, thus far pretty impressive.
Old 10-20-2018, 08:48 AM
Shikaitsu
Shikaitsu's Avatar
Juicy
Old 10-20-2018, 08:33 PM
Shortpersonbk
Shortpersonbk's Avatar
Looks like it really needs a better fuel and alot more boost/rpm to shine.
What size are these? High 60s on the compressor?
Old 10-20-2018, 09:44 PM
Mizfitcreations2.0
Mizfitcreations2.0's Avatar
following... nice numbers with that boost level.
Old 10-21-2018, 09:56 AM
Mizfitcreations2.0
Do you have top mount set ups like this for LS2?
Old 10-22-2018, 11:21 AM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
That's all in the works. Just breaking this in with baby steps since it's a new engine builder that we're not 100% familiar with. We'll be going to 110 oct and higher boost here really soon. Just waiting on Treadstone for the back ordered upgraded IC.
These are the big boy turbos, 76mm, so they haven't even begun to sneeze yet!.
This kit fits all the LS2/3 C6 cars. It was just made especially for the GS/Z06 because our normal fender-mount system interferes with the dry-sump oiling system.
Old 10-22-2018, 06:40 PM
Shortpersonbk
How far do you guys plan on taking it I assume the turbos have more in it then the block. Also given a twin setup does it use abnormally small hotside combinations to spool like that? I’m surprised I do not expect my single 75 to do that.
Old 10-22-2018, 10:32 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
The whole engine/trans/drive-line are built, so ultimately we're looking for the 1500-1600whp range. Not too small of a hot side, it's a standard T4-S3 with I believe a .81AR.
Old 11-01-2018, 03:38 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
For those of you guys on the fence...this should help.......
Exclusive deals for CF members, don't miss out!
Old 11-03-2018, 08:31 AM
Summerkruse13
Summerkruse13's Avatar
How did you guys set up at the PCV valve system on this Ls7 and assuming it's so has the dry sump?
Old 11-03-2018, 02:43 PM
0CK@UPPCOS
Former Vendor
CK@UPPCOS's Avatar
It's setup basically the same as factory, other than anything going to the intake pipe pre TB we vent to atmosphere.
To UPP T4's putting in work
Quick Reply: UPP T4's putting in work
