Oil cooler with thermostat AND supercharger supply? - CorvetteForum - Chevrolet Corvette Forum Discussion
C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Old 12-06-2018, 08:13 PM
sydneyACE
CF Senior Member
sydneyACE's Avatar
Default Oil cooler with thermostat AND supercharger supply?
Working on finishing up my LS3 with A&A V2 T-Trim.
Looking for an oil cooler adapter that has a thermostat AND provisions for my V2 oil feed/return.
Now, I initially though I could just "T" into the oil cooler lines... but if those are on a thermostat, then my SC wouldn't get any oil if the thermostat is closed.
Maybe I'm missing it, but I can't seem to find an oil cooler adapter that has provisions for both.
http://www.improvedracing.com/oil-co...ter-p-369.html
You guys see anything out there that would work?
sydneyACE is offline
Old 12-07-2018, 08:57 AM
Unreal
CF Senior Member
Unreal's Avatar
Why not just use the oil port on side of block like all the kits do?
Unreal is offline
Old 12-07-2018, 11:37 AM
sydneyACE
CF Senior Member
sydneyACE's Avatar
That's definitely an option. I would prefer not to drill and tap the pan for a return if I can help it.
Could a guy "T" into the return side of an oil cooler adapter or will that oil have too much pressure to act as an adequate return?
Old 12-07-2018, 12:49 PM
Unreal
CF Senior Member
Unreal's Avatar
Have to tap. That would not work.
Unreal is offline
Old 12-07-2018, 02:44 PM
stevieturbo
CF Senior Member
stevieturbo's Avatar
Simple, just drill/tap a -4 fitting into the "to cooler" area of the adapter.
Job done.
Or if you wanted oil from after...just drill/tap after the cooler. They even show you a picture to make it easy where you would need to drill.
stevieturbo is offline
Old 12-11-2018, 07:47 AM
mn_vette
CF Senior Member
mn_vette's Avatar
I agree, you want a constant flow to the supercharger for the supply. You would have to tap it off the main inlet or outlet of the thermostat, but not the lines going to the oil cooler. I'm not quite sure on a superchager, but on my turbos the drain MUST be a 0psi drain back to the oil pan. If it were pressurized it will not flow properly start blowing past seals.
mn_vette is offline
Old 12-11-2018, 12:29 PM
sydneyACE
CF Senior Member
sydneyACE's Avatar
Yeah, I see what you guys are saying. I'm just going to treat them like two completely different systems.
Fortunately the A&A kit comes with everything I need to plumb the supercharger, and the motor is out of the car, so It's going to be easy.
I always just assume that I need to buy extra stuff when I get things like this, but A&A REALLY did include everything.
I was just overthinking things and trying to get slick.
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
