Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C6 Corvette, 2005 - 2013 > C6 Forced Induction/Nitrous
Reload this Page >
Time to re-power the race car.. New goals 280mph and 2000ish HP
C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Old 12-09-2018, 08:39 PM
dmaxx3500
CF Senior Member
dmaxx3500's Avatar
watch a guy at
''6061.com''
this guy is amazing at tig welding anything
dmaxx3500 is online now
Old 12-10-2018, 05:53 PM
stevieturbo
CF Senior Member
stevieturbo's Avatar
Originally Posted by RecMech View Post
Not much done this weekend.. A couple small projects while waiting on parts. Back to the real job tomorrow.
I did start a new battery box.. This new Miller Dynasty Tig is great at hiding the fact that my hands shake like a leaf in a hurricane!
I wish my hands shook like that when welding !!! lol.
stevieturbo is offline
Old 12-11-2018, 12:59 AM
chuntington101
CF Senior Member
Any reason for going single over twins? Can’t wait to see more of this car!
chuntington101 is offline
Old 12-11-2018, 01:00 AM
vettemayhem
CF Senior Member
vettemayhem's Avatar
After running 267 mph this year on my original F1x setup, I have decided to re-power and go for the overall Corvette speed record in 2019.
Long block is out and getting upgraded. New billet crank, o-ringed heads, etc.
F1x and belt drive is out and being replaced. Not ordered yet, but I am leaning towards a 106mm single turbo up front. Car will retain the 2 stage direct port just in case!
I am thinking of running the inlet piping thru the front bumper again, air-to-water up front, radiator out back.
Staying with the manual trans for now, but we will see how it takes the power. A few small things to figure out, but it should be a fun winter getting everything put together.
Congratulations....looking forward to it! Too bad you had clutch slip on that last pass...I think you could have made 275mph with the 200 shot. Good luck!
vettemayhem is offline
Old 12-11-2018, 01:12 PM
Pekka_Perkeles
CF Senior Member
Pekka_Perkeles's Avatar
You mad.
Just..no words.
Pekka_Perkeles is offline
Old 12-11-2018, 04:25 PM
RecMech
CF Senior Member
RecMech's Avatar
Originally Posted by dmaxx3500 View Post
watch a guy at
''6061.com''
His stuff is amazing.. I copied one of his ideas and made a turntable out of random parts last year.
RecMech is offline
Old 12-11-2018, 04:27 PM
RecMech
CF Senior Member
RecMech's Avatar
Originally Posted by chuntington101 View Post
Any reason for going single over twins? Canít wait to see more of this car!
Simplicity in packaging mostly. I have no issue with a little lag, we struggle with traction anyways. The Precision 106mm should get us well over 2000 when needed.
RecMech is offline
Old 12-12-2018, 12:50 PM
RecMech
CF Senior Member
RecMech's Avatar
RecMech is offline
Old 12-12-2018, 12:57 PM
Tech
CF Senior Member
Tech's Avatar
That's a pretty serious vise ya got there.
Tech is offline
Old 12-12-2018, 01:21 PM
RecMech
CF Senior Member
RecMech's Avatar
Vise on the table is an old Columbian that I restored. The table was something I scored cheap, just because it took a ramp truck to move it!
RecMech is offline
Old 12-17-2018, 07:28 PM
RecMech
CF Senior Member
RecMech's Avatar
No new pics this week, but I did lock in some parts.
Golen Engine has the LSX block apart and is ordering a new Callies Ultra Billet crank, custom Wiseco's, lifters, cam, bearings, etc. etc. Goal is to make it good for 2500hp. They will be dyno-ing it N/A, so it has a proper break in (unlike last time )
The motor actually held up well over the past 3 years.. Bearings were all great, crank good, rods being re-used, pistons were a bit scuffed but I was spraying more than it was rated for.
Turbo is ordered.. Precision PT106CEA
Budget is pretty much blown, but apparently everything I am buying will cause cancer in CA, so... oh well !
RecMech is offline
Summerkruse13 (06-03-2019)
Old 12-17-2018, 07:34 PM
vettemayhem
CF Senior Member
Narrow Body Awesomeness on steroids...looking forward to the build detail and results.
Old 12-18-2018, 10:06 AM
  #33
schpenxel
CF Senior Member
schpenxel's Avatar
St. Jude Donor '15
Sub’d!
schpenxel is offline
Old 12-25-2018, 06:08 PM
  #34
ILLUSHN
CF Senior Member
ILLUSHN's Avatar
Keep showing how the narrow bodies do it!
ILLUSHN is offline
Old 12-26-2018, 09:38 AM
  #35
RecMech
CF Senior Member
RecMech's Avatar
Turbo arrived Saturday!!
RecMech is offline
Old 12-26-2018, 10:43 AM
  #36
silvrhand
CF Senior Member
Hehe I'm pretty sure that was a given when you started this
silvrhand is offline
Old 12-26-2018, 02:03 PM
  #37
Tuomas FIN
CF Senior Member
Tuomas FIN's Avatar
What manual transmission you have?
I should finally get shortly PPG seq internals together with billet case, hope it holds 2000hp but will see. Test installations done, some milling must make to the case anymore before final installation.
Tuomas FIN is offline
Old 12-26-2018, 02:21 PM
  #38
stevieturbo
CF Senior Member
This crowd are making some good claims about gearboxes.
https://racetechservicesinc.com/coll...s-new-releases
Old 12-26-2018, 02:34 PM
  #39
RecMech
CF Senior Member
RecMech's Avatar
Using an RPM TR6060 with ZR1 gearset, nothing fancy. I had to downgrade the rearend from ZR1 to Base model in order to get the gear ratio i needed as we got faster.
I have been following your build, hoping the billet trans works out!
RecMech is offline
Old 12-26-2018, 02:40 PM
  #40
RecMech
CF Senior Member
RecMech's Avatar
Those are some big claims.. Will be interesting to see how it works out.
RecMech is offline
Quick Reply: Time to re-power the race car.. New goals 280mph and 2000ish HP
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
