Time to re-power the race car.. New goals 280mph and 2000ish HP
sallen619 (04-21-2019)
#124
Is this Bob's page that did the alternator bracket?
https://www.facebook.com/Kasper-Fabr...4166273621297/
#127
Its been a little while since I have updated. Long story short, we had a part failure in the short block. Both the manufacturer and the machine shop have stepped up and all is being taken care of.
In the meantime, I have found time to clean up and paint the engine bay..
Wired up the new HO coils...
Figured out and installed the rear mount radiator, surge and recovery tanks, and water pump.. (still a little plumbing left to finish)
#128
Fabricated and installed a vented scavenge tank for the turbo and mounted the pump..
Started on the down pipe and cold side.. (the aluminum pipe has fittings from the old setup, blow-off's and sensors will be relocated on new piping)
#130
I did order a new Mechman 250A alternator to deal with the additional amp draw. Hopefully that along with the 6 rib will be as reliable as the old setup.
#131
The 4 rib setup only saw about 7150 rpm, even lower on the shifts. Zero issues other than when the 10 rib broke and wrapped around the 4 rib.
#133
It looks like the VFN hood is finally going on the car.. It clears the new intake pipe, my other hood will not work without more cutting (not to mention the VFN is a bunch lighter)
schpenxel (05-20-2019)
#136
Subbing! I love racecar ****.
NICK YOSKIN (04-03-2024)
#138
