C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Single turbo build
Old 02-04-2019, 05:06 PM
  #41
MTBSully
CF Senior Member
MTBSully's Avatar
Keep us posted!
MTBSully is online now
Old 02-08-2019, 02:51 AM
  #42
jayyyw
CF Senior Member
A couple more parts showed up. Cortex EBC, turbosmart wastegates, oil feed line
Also got the reluctor wheel on my motor swapped out and a -12an bung welded to the oil pan.
jayyyw is online now
Old 02-09-2019, 03:06 AM
  #43
jayyyw
CF Senior Member
Cold side and radiator showed up today.
Decided to sell the Huron hot parts. Back to the drawing board on that.
Old 02-09-2019, 09:51 AM
  #44
MTBSully
CF Senior Member
MTBSully's Avatar
CX racing cold side right?
Old 02-09-2019, 11:47 AM
  #45
jayyyw
CF Senior Member
Yeah
Old 02-11-2019, 04:31 PM
  #46
jayyyw
CF Senior Member
I sold my ID1000s and bought a set of the Bosch 210 injectors.
Still having trouble deciding which way to go for the fuel system.
The guy that bought the hot parts off me, gave me a set of F Body manifolds that have been cleaned up and had V Bands welded on them. I think these will work nicely. Now I just need to get the car over to the guy that's going to fab up the merge pipe.
Going to pick up the motor this week to take over to the shop where my car is currently sitting. I have to install the clutch and balancer and I can put the motor back into the car.
Still need an intake, stock TB, fuel system, fittings, and who knows what else. Gonna keep pushing along, slowly.
Old 02-11-2019, 05:53 PM
  #47
Innovate
CF Senior Member
Innovate's Avatar
Nice! Are you going to retain AC? I know the CX kit deletes it.
Innovate is offline
Old 02-11-2019, 07:14 PM
  #48
jayyyw
CF Senior Member
Nope, that's gone! If I drive the car to work, it's really early and I get out late. So it's never really hot. On my day's off I'll drive it around but I don't care about sweating. It's basically a Mexico car and some here and there driving.
Old 02-16-2019, 06:39 PM
  #49
jayyyw
CF Senior Member
Picked up the motor on Wednesday. Started putting my accessories on it. Mantic twin disc is installed, powerbond 25% UD balancer, going to stick a 160 degree thermostat in it.
Just need to pin the crank and itís ready to drop in.
Also installed the radiator and the intercooler.
Found out those F body manifolds wonít work. The passenger side exits right onto the motor mount bracket. These are 5th Gen LSA manifolds. They exit straight down. These should work out perfect.
Old 02-16-2019, 08:02 PM
  #50
MTPZ06
CF Senior Member
Support Corvetteforum!
MTPZ06's Avatar
Received 1,241 Likes on 1,086 Posts
I think hooker makes some “reasonably priced” turbo manifolds for LS motors.
MTPZ06 is online now
Old 02-17-2019, 08:25 AM
  #51
jayyyw
CF Senior Member
Originally Posted by MTPZ06 View Post
I think hooker makes some ďreasonably pricedĒ turbo manifolds for LS motors.
I asked around about those. Not a lot of info out there for this chassis, surprisingly. Also, not a lot of stuff that will fit unless it's proprietary. The Hooker manifolds hit the frame rails on the passenger side, from what I was told.
Old 02-17-2019, 03:18 PM
  #52
Innovate
CF Senior Member
Innovate's Avatar
Dang! Do it to it man. Texas gets hot and so does the cabin of these cars a little. I doubt I could bring myself to get rid of my AC.
LSA manifolds are the only ones that work? You could not use stock 5.3 manifolds?
Innovate is offline
Old 02-17-2019, 08:02 PM
  #53
MTPZ06
CF Senior Member
MTPZ06's Avatar
They look like they hug the block pretty good, but yeah...I honestly couldnít tell you how they fit in our engine bay.
Old 02-18-2019, 08:32 AM
  #54
jayyyw
CF Senior Member
Going to order some mandrel bends, T4 flange, v-band connections, and other misc. Going to attempt to mock up the hot side on my own.
MTBSully (02-18-2019)
Old 02-18-2019, 08:40 AM
  #55
MTBSully
CF Senior Member
MTBSully's Avatar
Good luck and keep us posted! Where are you ordering material from. If the manifolds exit straight down, where are you planning to mount the turbo?
Old 02-18-2019, 09:20 AM
  #56
jayyyw
CF Senior Member
My engine builder uses Performance Tube Bending, so likely from there. He also recommended running double slip joints instead of a mesh flex coupler. Going to order the T4 flange and waste gate tubes from Monkey Fab.
The CX racing cold side is setup to have the turbo mounted right in front of the water pump. So, from the looks of it, I'll need (2) 90 degree bends off the manifolds; kind of angled inwards towards the center of the motor. Then (2) 45 degree bends up into the collector.
Old 02-18-2019, 01:01 PM
  #57
MTPZ06
CF Senior Member
MTPZ06's Avatar
Getting a better look at those on a larger screen...it does look like clearance could be an issue.
Old 02-18-2019, 09:28 PM
  #58
Innovate
CF Senior Member
Innovate's Avatar
Those do look like they would be all up in the frame rail. Did you have to convert to wet-sump John or you just did it anyway with the 5.3 swap? With my heads coming off this week prepping for boost is tempting.
Innovate is offline
Old 02-19-2019, 10:09 AM
  #59
jayyyw
CF Senior Member
It's a wet sump engine. No conversion necessary.
Old 02-19-2019, 02:52 PM
  #60
Innovate
CF Senior Member
Innovate's Avatar
Ah ok. It looks like a ton of Vette's are wet sump that are going turbo anyway.
Innovate is offline
Quick Reply: Single turbo build
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
