C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Single turbo build
Old 03-10-2019, 10:03 AM
  #81
jayyyw
jayyyw's Avatar
Just did it for the peace of mind. I don't want to have issues down the road. I had easy access to it. I actually double pinned it, which is way overkill. Haha.
Old 03-10-2019, 04:03 PM
  #82
Garrett Brooks
Garrett Brooks's Avatar
Originally Posted by jayyyw
Motor is in. Crank is pinned. Forgot to torque down the ARP crank bolt so I have to drop the subframe again and do that.
Turbo shipped and should be here early next week.
Should be able to torque with it in the car. I just did mine on my ls3 with it in the car.
Old 03-10-2019, 04:25 PM
  #83
schpenxel
schpenxel's Avatar
Received 1,194 Likes on 1,053 Posts
St. Jude Donor '15
Agree on pinning the crank.. I’ve seen one come loose on a turbo setup, 800’ish rwhp
jayyyw (03-10-2019)
Old 03-10-2019, 05:28 PM
  #84
Turbo2L
Turbo2L's Avatar
In for hotside pics.
jayyyw (03-10-2019)
Old 03-17-2019, 01:11 AM
  #85
jayyyw
jayyyw's Avatar
Unfortunately, no hot side progress this week. We did come up with a plan. Those LSA manifolds are not gonna work for the driver side. It’s too close to the steering shaft joint. I’ll be using the OEM LS2/LS3 manifolds. Probably won’t have anything for another 2 weeks or so. I’m going out of town later this week.
I did wire up the boost controller, relocate my wideband to the driver side a/c vent, cleaned up some old wiring, mounted my catch can, torqued the crank bolt, trimmed the bumper to fit with the intercooler(went a little crazy but doesn’t look bad), changed the trans fluid with some fresh Pennzoil Synchromesh, looped the trans cooler lines, and a few other small things.
Worked till midnight 3 days in a row, lol.
Old 03-19-2019, 08:32 AM
  #86
jayyyw
jayyyw's Avatar
Ordered some of the materials I need to make the merge pipe. 4 2.5" v-bands, 1 4" v-band, 2.5" divided T4 flange with legs, o2 sensor bung. Hoping to drop the car off on Sunday. My fab guy says it should be a 1 week turn around. Once that is done, I'll have the hot side coated and try to find a cathedral intake to borrow until my BTR intake gets here. I need to put some miles on my clutch before I can really lay into the tuning.
Who do you guys like for injector flow bench testing?
Old 03-19-2019, 09:35 AM
  #87
Dr.BlueDevil
Dr.BlueDevil's Avatar
For my 2008 vette i used camaro 2010 ss manifold
But for rear mount turbo
Old 03-19-2019, 06:10 PM
  #88
jayyyw
jayyyw's Avatar
I need to look for a throttle body. I have an 08 model that came standard with a silver blade TB. From what I've read, I can use either the silver or gold as long as it's tuned for the one I'm using. I was tuned for a NW102 and I've read that people use the internals from the gold blade TBs to fix broken NW TBs. Is either TB better than the other, gold or silver?
Old 03-19-2019, 06:13 PM
  #89
g23crawler
g23crawler's Avatar
Im also curious, I think my TB is causing problems. Its a silver blade on my 08, iv heard gold is better?
Old 03-19-2019, 07:19 PM
  #90
MTPZ06
Support Corvetteforum!
MTPZ06's Avatar
Received 1,592 Likes on 1,335 Posts
Hmmm...I've always read the earlier LS2 silver blade TB's have the stronger motor versus the LS3/LS7 gold blade TB's. Brand new GM silver blade TB's cost at least double what the gold blade TB's do as well.
Old 03-19-2019, 07:31 PM
  #91
g23crawler
g23crawler's Avatar
I may have my colors mixed around lol
Old 03-24-2019, 02:34 PM
  #92
Creamo3
Creamo3's Avatar
Great looking build! I recently switched from silver to gold on my 07'. Started up fine, idles fine, and cruises without issue on my car with no codes thrown. I replaced the silver blade due to REP and wanting to get something newer/stronger for boost since this is the motor NW uses. My logic is if you can tune for a NW102 there should be no reason why you couldn't get a gold blade to work. I didn't adjust anything in the tune either, but my car is running an ECU from a 2010 C6Z which may have something to do with it.
Old 03-25-2019, 08:28 AM
  #93
jayyyw
jayyyw's Avatar
Thanks for the info.
Hoping to drop the car off to have the hot side done up, this week.
Old 04-03-2019, 04:45 PM
  #94
jayyyw
jayyyw's Avatar
Going to mock up the hot side on my own. Ordered some manifolds that will hopefully make it a little easier for me. Just need to decide if I want to have the merge above or below the turbo. That is, if there is enough room to route the merge below.
Old 04-04-2019, 12:15 AM
  #95
Innovate
Innovate's Avatar
Dang, what happened to dropping it off for the hot side to be done? Either way I am looking forward to how it is routed. I like how everything is coming together so far.
Old 04-07-2019, 08:37 AM
  #96
jayyyw
jayyyw's Avatar
Seems like my buddy didn't want to make some extra money. Gave him over 3 weeks to make space for my car and he never did. Oh well, I will try to do it myself.
Old 04-09-2019, 11:11 PM
  #97
Innovate
Innovate's Avatar
Haha I know how that goes, sometimes it is best to do things yourself. Measure a ton and cut once.
To Single turbo build
Old 04-13-2019, 07:52 AM
  #98
jayyyw
jayyyw's Avatar
Finally have some updates!
Got the hot side mocked up and welded with the help from a few friends. Came out awesome!
Had to move the relay box out of the way and modify one of the runners on the driver side manifold.
Gonna order the fittings and **** that I need to plumb the feed and return, some Spal fans to replace the shitty CX racing ones, Ordered some aluminum for the cold side, and 4” bends for the exhaust.
I am working on wastegate placement next and a way to brace the hot side.
My tuner hooked me up with a Fore triple pump system and it’s on the way. Primary is a 450 and two 525s secondary. FC3 controller and the works.
schpenxel (04-15-2019)
Old 04-15-2019, 01:05 PM
  #99
MTPZ06
MTPZ06's Avatar
Looks awesome. What headers are those?
Old 04-15-2019, 04:19 PM
  #100
jayyyw
jayyyw's Avatar
Flowtech 1-3/4" with the collectors modified for 2.5" exits, instead of the 3" they come with.
Quick Reply: Single turbo build
