Cooling recommendation needed for ls3 with A&A kit
Platinum Supporting Vendor
https://aacorvette.com/shop/product/...ance-radiator/
If you're going to buy a radiator, there's nothing better.
I also agree with the fans. The Spal setup flows worse than the stock one.
I haven't tried the ProSpeed but I've heard good things.
PLEASE TAKE A MOMENT TO VISIT OUR WEBSITE AT WWW.AACORVETTE.COM
NOW PARTNERING WITH AFFIRM TO OFFER INTEREST FREE FINANCING!
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE SUPERCHARGER SYSTEMS
HOME OF THE WORLDS FIRST
CENTRIFUGALLY SUPERCHARGED C7
SUPERIOR ENGINEERING- SUPERIOR POWER
SUPERIOR PRICING- SUPERIOR CUSTOMER SUPPORT
Andy@AACorvette.com 805- 278 4107
Our radiator is a full 3" thick vs. 2 1/2" for the DeWitts. I also took 2 rows out of the top, for clearance, but added them back at the bottom so as not to reduce any cooling capacity. There's more airflow at the bottom where the two rows were added as well.
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
A&A CORVETTE
477 LAMBERT ST
OXNARD CA 93036
WWW.AACorvette.com
Former Vendor
Epoxy Filled headers
Sorry to bring this thread back to the top but im looking to pull the trigger on the prospeed fans. And my question is if anything needs to be modified in order to fit the A&A kit? Because i installed the kit last week and it was pretty tight getting the intake on and i had to trim some off the top of the stock radiator for it to fit. So im worried that ill need to chop up the $900 fans. Not sure why prospeed didnt reverse the position on the fans.
Does anyone know any tips and tricks or maybe run into the same problem? Do you think the shortened fans would work?
Thanks again,
Albert
Thanks again,
Albert
Same fans for both kits, just different shroud, so no the shortened ones won't work.
They should go right on.
I ordered the Prospeed shroud kit a week ago and was told there was a three week back log. Got an email today with tracking info!! Woo Hoo!! What a NICE surprise!!! ETA Friday 3/22/19
Looking forward to getting this installed on my 2011 Dry Sump GS with A&A Ti V3 kit.
Cheers!!
Cheers!!
My ECS blower vette is currently at Prospeed for cam + meth install and I’m having them put in their fan kit. I will hopefully report back positive results. From my resesrch and their recommendation, the OEM radiator is pretty capable so it makes sense to start by increasing airflow prior to replacing radiator. That being said, there are many nice radiator options if fans don’t cut it.
Cheers!!
Cheers!!
Thanks,
Albert
#33
Thanks,
Albert
#34
Former Vendor
There are a lot of good options here. We use the Dewitt radiators on all supercharged C5/C6 cars here and typically run the brushless fan kit if space allows or the ProSpeed fan/shroud kit as well. This is a bullet proof combo and we are dealers for all of it if you need some help with an order!
