Gauges for boosted cars - leaning towards ngauge
I'm currently working on my parts list for my supercharger install.
I'd like at least a AF gauge with wideband and probably boost gauge. I love the look of the ngauge. Is anybody using this gauge and if so what paramaters are you monitoring?
My Ngauge is in a box waiting to go into the car here over the next few weeks as we finish up the winter build. I'll keep you posted but I definitely went with a separate AFR and Boost gauge as it's easier to read and the ngauge is more for logging and ethanol content readout for me.
I have one and am monitoring boost, ethanol content, oil pressure, oil temp, AFR (analog Via an NGK Powerdex - I also have an HPT Pro EOIO spliced in so I can leave the ngauge connected if I want to data log AFR) and one other I can't remember as I haven't driven the car in a while.
I had a 5th gen camaro that had an ngauge also and I also had a separate AFR gauge. For the vette, I wanted a cleaner look so I decided to use it for AFR also.
Once you get used to where the parameters are on the screen, it is easy to look and get the information you need. I also have it set up so the numbers change colors depending on what range they are in. E.G. when oil gets over 160*, the font turns green. If oil pressure is too low, the font turns red.
I'm also running an ngauge. Using it to monitor (AFR - using AFX 2 wideband, oil pres., coolant temp, fuel pres., knock retard, oil temp.)
Like the previous person, it's easy to read once you know where you placed everything and the color changing option is pretty cool for quick visual alerts.
I already had a seperate gauge for boost, which I'm using.
I run one on my ctsv, it won't read on my old c5z. They've very nice and their support is excellent. I accidentally broke the screen when I had mine out. They had it fixed and back to me within 4-5 days.
I am located in KCMO... actually just south in Belton.
I'm by Liberty. The guy who bought my car lives in Belton. If you see a black 5th Gen with 17" weld beadlocks and a cowl induction hood... Beware, it makes just over 1kwhp on the lowest boost setting and over 1200whp on high...
Don't tell him I told you.
Just got home from KCMO. Damn it was cold. Happy to be back into the mid 70s and sunny.
As for gauges, Aeroforce, innovate, dashlogic and many other single gauge type choices to consider.
This gauge search has sent me down the rabbit hole. There are just so many options and I'm still learning as I go.
Actually this whole forced induction quest has sent me down the rabbit hole. Now I'm also at the point of deciding if I need to add a secondary fuel pump system from A&A to meet my goals. Then there is the bottom end to consider the need for upgrades, what to do about the z51 oil cooler, etc.
I think I've narrowed it down between:
nGauge w/ zeitronix zt-3 for wideband
Innovative ECB-1 (BOOST) Ethanol Content & Air/Fuel Ratio Gauge
Innovative PSB-1 Boost & A/F Gauge
Still leaning towards the nGauge, but I wouldn't mind saving the couple hundred bucks on the Innovative.
AEM failsafe also does what you want, is cheap and works. Has AFR, boost, and also can be wired up for the fail safe functions.
Originally Posted by grdspt
how are you guys hooking up any of these mentioned wideband sensors to the ngauge? what sensor/harness adapter would be needed?
grdspt (08-13-2019)
