Thinking of Edelbrock E-Force
So I have a 2011 Corvette Grand Sport. It is a 6-speed manual so it has the LS3 with the dry sump oiling system. I am thinking I may purchase an Edelbrock E-force supercharger kit for it. More power would be great and I love doing installs/upgrades to my car.
Anyone here done an install themselves of this kit? Any advice or pointers? I have read some older threads and looks like the most difficult part is the crank pinning.
Any thing else?
My only current modification is American Racing headers and a canned tune. I assume that I can continue to use my headers with the E-Force?
Any thing else?
Received 2,828 Likes
2021 C6 of the Year Finalist - Modified
I'm thinking about one of those also for my GS. A simpler install is one reason and looks clean...... I think its a simpler install anyway......
As for which has the cleaner look, I think the E-force but either system looks to be very well engineered so that doesn't matter much to me.
I do like the fact that the E-force comes with a factory tune. I could always find a local tuner if I wanted a more refined tune for my car.
The E-force does come with a warranty but I would be doing the install myself, so that doesn't matter.
sallen619 (03-17-2019)
My car already had the Eforce installed when I bought it but it really doesn't look that hard, crank pinning and fuel pump work might be a little labor but nothing that can't be done. Where are you located?
I think pinning the crank and tapping the pan for oil is probably the hardest with any of the kits. I think they all have good instructions, maybe the Maggie heartbeat being the most lacking as far as I can tell. Can't remember if either it or the Edelbrock are self contained but one of the reasons why I'm favoring more towards AA or ECS.
You have access to 2 or 4 post lift? Going to blog about it? Would be interested to follow, see if I have enough Kung Fu to try it myself with my drys sump LS3.
Yeah, the install doesn't look difficult at all. I have already done two cam installs on LS cars so I am familiar with how to remove the balancer bolt. It still makes me pucker up when I have to do that.
I will probably drop the subframe and raise the engine to make room to pin the crank. Definitely, seems to save a good bit of work rather than remove the power steering rack.
As for pump install, I went with the 554 hp kit which doesn't require upgrading the fuel pump. If I decide I want or need to increase the amount of fuel pressure/volume, I would probably just install a Boost-A-Pump and a auxillary wiring harness.
The Edelbrock E-force is self contained to there is no tapping into the oil pan for an oil drain.
I will try to take as many pictures as I can when I do the install. I don't think it will be too difficult. I have read the instructions and it looks pretty straight forward.
I don't have a lift so will be doing this on jack stands. I did a clutch install last year on a C5 Z06 on jack stands so this shouldn't be too bad.
Any thing else?
Any thing else?
