C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Sloppyish Homemade Turbo Build
Old 07-02-2019, 04:34 PM
  #41
CHR89
CF Member
CHR89's Avatar
Originally Posted by VVVROOMTX View Post
subd for another cool build!
also why, and this might already be answered, but why such thick walled pipe for the manifolds and piping?
I could have likely done it with much thinner walled pipe but went overkill, lots of local guys are building their log manifolds out of the same so I just followed the trend. Thinner would have been fine for sure since the turbo is mounted to the subframe.
Originally Posted by SteveSierra View Post
Very nice work.
Iím a little concerned as my turbo isnít braced. The kit I bought just had it connected to the header, Is this sufficient?
It should be fine, my turbo is roughly 60# and that's obviously a lot of weight to hang as far forward as I have, lots still don't brace them the same size as mine but I wanted to be able to take the turbo off via the vband and also wanted to mount it to the subframe so my terrible welds have a chance at survival lol.
Originally Posted by Tokuzumi View Post
I can't imagine how long it took to put together the bottom half of that pipe.
few hours, it sucked pretty bad but I mounted the turbo too low and all of my 4" 90s had a 6" CLR so I couldn't get it to tuck up above the factory radiator support. Would have MUCH rather just used a single bend though.
CHR89 is offline
MTBSully (07-02-2019)
Old 07-02-2019, 04:50 PM
  #42
MTBSully
CF Senior Member
MTBSully's Avatar
Where did you order the stainless for the crossover and downpipe? Looks like summit has a good selection. I will be ordering my manifold stuff from ace race parts here shortly.
MTBSully is offline
Old 07-02-2019, 08:26 PM
  #43
CHR89
CF Member
CHR89's Avatar
Stainless for the manifold and crossover was ordered from ace race parts, downpipe steel came from global tech eng, header flanges were ordered from LJMS because they have ones that are meant to be used with weld elís. And the rest of the misc stuff like the vbands came from MonkeyFab.
CHR89 is offline
MTBSully (07-03-2019)
Old 07-13-2019, 10:20 PM
  #44
CHR89
CF Member
CHR89's Avatar
Finally got around to working on the intercooler piping. Finished up the hot side and got most of the cold side complete. The coupler in the middle of the cold side is going away once I get more argon and get the coupler for the throttle body, so that I can be sure it fits right. Need to get the BOV flange and IAT sensor on as well since the car is going speed density.
My buddy is making my oil feed line right now, I got the 12an return built and hooked up today as well. Also decided Iím putting the radiator in the back to try to avoid all of the coolant temp issues people seem to be running into.
CHR89 is offline
Old 07-15-2019, 08:58 AM
  #45
MTBSully
CF Senior Member
MTBSully's Avatar
Looks good man! How does the CX racing stuff fit? I assume you just bought their intercooler/radiator and are going to do your own cold side piping? I think that is my plan as of right now as well
MTBSully is offline
Old 07-15-2019, 09:02 AM
  #46
CHR89
CF Member
CHR89's Avatar
Yeah, I just bought their intercooler and radiator kit but I'm only going to be using the intercooler. I'm putting the radiator in the rear of the car. The cold/hot piping is just a generic ebay kit that was like 80 bucks cut and welded together myself to fit how I wanted it to. I ran out of argon before I could finish it so for the most part it's just tacked together. I think total I'll be using 5 couplers, may try to get it down to 4 though.
CHR89 is offline
Old 07-15-2019, 09:47 AM
  #47
Tokuzumi
CF Senior Member
Tokuzumi's Avatar
I'm no expert, but I'm pretty sure you are going to have some boost leaks around the throttle body area. May want to look into sealing up around that area a little better.
Tokuzumi is offline
Old 07-15-2019, 09:56 AM
  #48
CHR89
CF Member
CHR89's Avatar
Just waiting on the 3-4" reduction coupler and more argon lol
CHR89 is offline
Old 07-15-2019, 10:05 AM
  #49
MTBSully
CF Senior Member
MTBSully's Avatar
I have my eye on the same 80 dollar ebay kit haha
MTBSully is offline
Old 07-15-2019, 10:10 AM
  #50
CHR89
CF Member
CHR89's Avatar
It welds just fine if you have argon lol I was fighting it for like 20 minutes before realizing my tank was empty.
CHR89 is offline
MTBSully (07-15-2019)
Quick Reply: Sloppyish Homemade Turbo Build
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
