C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Sloppyish Homemade Turbo Build
Old 04-15-2019, 02:10 PM
CHR89
CF Member
CHR89's Avatar
Default Sloppyish Homemade Turbo Build
Decided I might as well make a build thread since it seems like everyone else is doing it. The car started out as a SBE ls2/eforce setup. I ended up cracking 3 pistonís ringlands and took it apart to have Thompson Motorsports build me a block. They rebuilt my block with a K1 crank, K1 Rods, and Diamond pistons. I went ahead and put this all back together along with WCCH heads and the eforce. I pretty well maxíd it out on an LS2 with the 10% overdriven crank pulley and 2.75Ē blower pulley.
It was a decent amount of fun but I felt like I was at a point where I was making too much low end torque to run 26s on the street but hardly enough power to utilize the 28s up top. That and constantly fighting 185+ degree IATs on 50 degree nights got annoying. The car was on E85, Methanol, had a 7gal ice tank in the back, bigger HX, and was still running into issues when Iíd make a second pull. Went ahead and sold all of this to switch to a single turbo. Everything I have built in the past has been turbocharged so itís nothing unfamiliar I was just burnt out on the blower.
I am piecing together most of the kit myself, building the manifold/intercooler pipe etc. I went ahead and switched to a CX Racing Radiator/Intercooler setup so that I could mount the turbo in front of the engine.
The kit will consist of:
  • CX Racing Intercooler/Radiator Kit
  • OEM Driver side exhaust manifold w/ crossover behind block/bellhousing
  • Log style passenger manifold
  • VS Racing Billet Wheel s480 clone w/ 4Ē bumper exit ďexhaustĒ
  • VS Racing 60mm Wastegate and 50mm BOV
Already on the car is:
Fuel:
  • 450 Intank pump w/ LPE blockoffs
  • Twin 044 Externally mounted pumps
  • Magnafuel regulator
  • 10an feed splitting to 8an behind the rails
  • Stock feed as return
  • FIC 127# Injectors (These will be upgraded)
Engine:
  • LS2 Block (K1 Crank, K1 Rods, Diamond Pistons)
  • WCCH 243 Heads
  • GPTuning Camshaft
Drivetrain:
  • ∑TDP Built T56
  • ∑TDP Built 07+ Rear End
  • ∑Centerforce DYAD twin disk (this will die)
Obviously there is a lot I left off on the car but it gives a generic rundown of what I already have. Hoping to get the manifold welded up this weekend and get the turbo hung from it. I have spent a ton of time working on other peopleís cars lately so I have not had time to mess with mine except for once a week or so it seems like. Going to be having all of the hot parts coated especially since the driver side manifold looks like trash.
CHR89 is offline
Old 04-15-2019, 03:59 PM
g23crawler
CF Senior Member
g23crawler's Avatar
Nice! Even better starting with a solid platform.
g23crawler is offline
Old 04-15-2019, 05:25 PM
jayyyw
CF Senior Member
sub'd for another turbo build!
I used a lot of the same parts.
jayyyw is offline
Old 04-15-2019, 05:35 PM
CHR89
CF Member
CHR89's Avatar
lol yeah, I replied to you on Facebook when you were looking for an alternator relocation. I figured I might as well make one of these since everyone else did.
CHR89 is offline
jayyyw (04-15-2019)
Old 04-15-2019, 05:44 PM
jayyyw
CF Senior Member
Ah, lol. Nice.
jayyyw is offline
Old 04-15-2019, 09:00 PM
CHR89
CF Member
CHR89's Avatar
Ended up rebuilding the turbo manifold and putting the log portion below the runners instead of above. I didnít want a short runner up front and thatís about my only choice while maintaining AC but my buddy told me it shouldnít be an issue so I guess Iíll just run with it.
CHR89 is offline
Old 04-15-2019, 10:01 PM
Shortpersonbk
CF Senior Member
Shortpersonbk's Avatar
Looks very similar to my setup. Subscribed.
Shortpersonbk is offline
Old 04-15-2019, 11:02 PM
CHR89
CF Member
CHR89's Avatar
Yeah keeping mine under the hood and retaining AC but otherwise similar in that itís using a log manifold. Did you use a stock manifold for your driver side as well?
CHR89 is offline
Old 04-16-2019, 09:13 AM
MTBSully
CF Senior Member
MTBSully's Avatar
badass man. Loving all these single turbo builds, hoping to start mine in the coming weeks, and hoping to build an almost identical hotside (stock drivers manifold, log passenger, fender exit exhaust).
Details on the log manifold? Size of piping and primaries? Dont skimp on the pics! lol. Also where did you order the piping from?
MTBSully is offline
jayyyw (04-16-2019)
Old 04-16-2019, 09:39 AM
CHR89
CF Member
CHR89's Avatar
The log is basically 1 2.5" sch 10 short radius 90 towards the back that will connect to the crossover via vband. The log is 2.5" sch 10, and the front is 2x 2.5" sch 10 log radius 90s. All runners are 1.5" sch 10.
I bought all tubing and piping from Ace Race Parts, the vbands are from Monkey Fab Garage, and the flanges for the passenger side log are from PRL Motorsports. The flanges are only 80 bucks for 2 of them in 1/2" which was one of the best deals I could find, plus they are a perfect fit for the 1.5" pipe fittings.
I will try to get more pictures up after work today.
CHR89 is offline
Old 04-16-2019, 10:32 AM
MTBSully
CF Senior Member
MTBSully's Avatar
Awesome thanks man. This will be my first real fab project so this is very helpful. You doing a T4 or T6 turbo flange? Wheres the wastegate going?
MTBSully is offline
Old 04-16-2019, 01:11 PM
CHR89
CF Member
CHR89's Avatar
Same lol, bought a tig and kind of been playing with it a little but before a few months ago I have never really built too much. I'm sure it'll crack eventually but that's alright lol. I went with a T6 flange though.
CHR89 is offline
Old 04-16-2019, 01:18 PM
Tool Hoarder
CF Senior Member
Tool Hoarder's Avatar
Received 2,621 Likes on 1,365 Posts
Sub'd.
Tool Hoarder is offline
Old 04-16-2019, 02:00 PM
SteveSierra
CF Senior Member
Hi can I ask why you went with the log low instead of high?
are you going to run a fender exhaust?
i have a very similar setup with a 2.5Ē downpipe and rear exit exhaust. Itís soon going back in so they can extend the log so itís higher up and hopefully allow the space for the downpipe to be increased to 3.5-4Ē.
SteveSierra is offline
Old 04-16-2019, 04:14 PM
CHR89
CF Member
CHR89's Avatar
I was going to do it high but it made the plugs way harder to change. Where it's at now I can get to all of them just as easily as I could with regular headers. It also set the crossover down lower so I didn't have to move any wiring that goes across the firewall. I am doing a 4" bumper or hood exit exhaust though. I haven't decided which at this point.
CHR89 is offline
Old 04-16-2019, 10:25 PM
schpenxel
CF Senior Member
schpenxel's Avatar
St. Jude Donor '15
Sub’d
schpenxel is online now
Old 04-17-2019, 08:42 PM
CHR89
CF Member
CHR89's Avatar
Well so far the manifold isnít turning out too bad, but itís not too good either 😂 itís going to crack for sure but thatís alright, itís a learning process. First thing Iíve ever really built so Iíll be interested to see how long it lasts. Iíll finish it up tomorrow, ran out of argon today.
CHR89 is offline
Old 04-17-2019, 10:57 PM
Shortpersonbk
CF Senior Member
Everything backpurged and such?
Old 04-17-2019, 11:22 PM
CHR89
CF Member
CHR89's Avatar
yup, I just donít have much faith in literally the first thing like this Iíve ever built lol. Iíve only had a welder for a few months and just killed my first 125 of argon so Iím super new.
CHR89 is offline
Old 04-18-2019, 08:15 AM
MTBSully
CF Senior Member
MTBSully's Avatar
Looks good to me but what do I know. What tig do you have? The new vulcan pro tig from harbor freight has been getting really good reviews I was thinking of picking that up as my first rig.
MTBSully is offline
Quick Reply: Sloppyish Homemade Turbo Build
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
