C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
2008 LS3 Rear Mount Turbo Build
Old 05-17-2019, 10:26 AM
Unreal
Unreal's Avatar
Received 2,313 Likes on 1,793 Posts
Stock manifolds are not multipiece, held together with gaskets. They are much much thicker, and have molded in support beams. That being said, stock ones still split at 20+ psi with time and heat cycles.
Old 05-17-2019, 10:27 AM
irok
irok's Avatar
Seems odd that cars using the correct button head bolts in valley cover and 89 in/lbs of torque on manifold bolts running a lot more boost run for years with no issues?
Old 05-17-2019, 11:19 AM
Unreal
Unreal's Avatar
I think a lot of it is like the head issue, they say no issue, but if they actually leak checked it they would find the main seal is probably acting as a safety device and blown out. I've only seen 1 fast actually tested that wasn't leaking after some mileage.
And sure, some run without issues, some don't. When issues occur they can take the motor out and cause massive issues. There is very little to no power gain, and high risk, and cost, so it is pretty much a lose/lose situation.
Old 05-17-2019, 12:06 PM
irok
irok's Avatar
Some of the Fast manifolds I've checked were leaking due to improper torque on manifold bolts.Comp says 2 pass's on the bolts but some took as many as 5 or 6 pass's to get up to torque with no thread locker.After all up to torque removed 1 bolt at a time in reverse torque sequence and applied thread locker.Never leaked again
Quick Reply: 2008 LS3 Rear Mount Turbo Build
