If you were doing it again. Where would you stop?
That was a RPM built 56. Now it has a RPM built 6060. Once you go big, you need to expect breakage. EVERYTHING breaks at some point. Don't get me started on my bent Dragonslayer crank..... No guarantees on race car stuff....
It has the stock heat exchanger the kit came with.
Not sure what my IAT's are. Haven't data logged the car. I don't worry about any kind of heat soak or anything as the car is street driven.
The main cooling upgrade that I did to the car when I did the E-force install was to upgrade to a DeWitts radiator.
I also have an RPM t56 trans and RPM rear, looking at your picture might give me some sleepless nights!
Haven't dynoed it. It has the 3" pulley on it that the 599 Hp kit comes with so if there is the typical 12 to 15% drivetrain loss, it should be right around 500 to the wheels.
I was in that EXACT same position, and plans. Then after time, I wanted to bump it up a notch.
However for me if I had it to do all over again, I would have picked up a decent ZR1 and have started there. Better platform (LS9?) and better resale (like resale is ever a factor, LOL).
At 750 I think I'll be happy for quite a while.
The best fun:stress ratio was when I was right at 600rwhp.
Now around 800rwhp Its a blast but in the back of my mind im anxious about it blowing
The following 2 users liked this post by Dimewise:
Chiselchst (05-23-2019),
Indy c6GS (05-27-2019)
Great thread!!!!!
Tom
You on SBE LS7? I am near the same power (meth/heads/cam/8psi ECS 1500 kit/flexfuel) and It's always spining in the back of my head.
I will keep making the car faster as long as i can return it to stock. Or at least how i bought it. As a 700hp car that you can daily drive. Now the car is a high mount twin turbo car, and was not cut up to do it.
m60gov20 (05-25-2019)
I like the power I make now but I don’t have a built motor yet. Once I do that with a set of heads then that will be my stopping point unless something needs repair.
harleyreb1 (05-24-2019)
#33
I'm leaving mine basically stock. I used HP Tuners to tweak shift rpms and mph to my liking and removed most of the torque management, and tweaked a few other selected parameters. Added a Vitesse to get rid of the lame OEM throttle programming and set it to my liking.
I went down the slippery modification slope with a 2002 Avalanche and while it was fun and made for a surprisingly fast 6200 pound pig of a truck, as anyone who has done it knows, it was expensive! Once you start it's hard to stop!
#34
If i had known now what I had known then:
- I would have started with a ZR1, the Z06 LS7 doesn't take well to many things and has it's own set of problems.
- about 700rwhp would have been fine, past that you start having traction problems run slicks/drag radials and break stuff.
- I wouldn't have gone 19/20" rims, I would have stayed at 18/19" rims for a better tire selection.
- clutches.. jfc.. I hate this that topic, just pay up front for a good one.. take the hit early, again staying at or below 700rwhp makes this an easier problem.
#35
#36
Summerkruse13 (05-25-2019)
Summerkruse13 (05-26-2019)
#38
I recently did it again. I stopped right before adding the blower. N/A this time around. Ported LS3 heads along with a mild cam and bolt ons. Ended up with 500 at the wheels with near perfect manners and decent fuel eco. Fun Vette with minor suspension upgrades too.
harleyreb1 (05-26-2019)
The following 2 users liked this post by jimbob8915:
LightningBrett (03-22-2020),
schpenxel (05-27-2019)
