Porting a Magnuson Heartbeat supercharger
Thinking about installing a Heartbeat onto my 06 Z06. Has anyone ever heard of or had their TVS 2300 ported? Any flow gains from the supercharger or manifold to be had? I think that improving flow should lower boost but also will lower heat.
The Heartbeat is a completely different casing and the only thing that I can see would benefit from porting on that would be the inlet snout or Throttle Body Adaptor (“TBA”). But to do that properly, you need to weld up the outside of the TBA and then port it out to ~102mm so you can use a 102mm throttle body. That’s what I did and picked up about 1.5 psi of boost and a noticeable power gain.
