Cutting open the front bumper ?
I asked about fitment , he basically stated it should fit like oem. The bumper is fabricated in Germany so the quality control should be decent I would think. Only thing is the $2k price, not cheap, but I think a good % of that cost is due to being an oversized item and shipped from overseas. Either way I have yet to see another c6 Z with a front bumper that looks that bad *** !
Nice! Any pics of the bumper off? Also looks like you made the opening narrower so it just feeds the intercooler? I think it looks good!
Quick question on the Geiger bumper, how much of the crash bar would block the flow? Guessing anyone that used it would have to have a cut crash bar to get the most out of it?..
Yes sir, the opening is narrower + blocked the fog lights openings.
Next step to do some aluminium plates to close all the area around the intercooler and bumper as I could not forward the intercooler closer to bumper (without angle it) due to its size and hitting the bumper from the top middle outlet pipe.
Cutting the crash bar helps with or without the Geiger bumper. The larger opening in the Geiger brings more air around the intercooler without it. Also the side ducts add more air flow that can be ducted wherever.
Are we talking about the white bumper being able to potentially group buy? Or the matte gray version that another member already has? I looked all over their site and didn’t find the version pictured on the white Z, it seems they did those top slits afterwards. $2k is a healthy price and I’d have to agree with Unreal the fitment is probably gonna be a bitch....and it’s gonna need paint. I’d just assume cut into mine or bring it to a shop and have pro’s do it....no fitment problems and no need to paint...
If the object of the exercise is to get more air through the radiator on a car with an intercooler, then probably the easiest/best way to do that would be to cut out the back of the metal bumper like Pat G did:
https://www.corvetteforum.com/forums...rformance.html
Or cut the whole damn bumper out and replace it with a tubular bar, although if you do that you would probably need to discard the foam nose support, which would mean that you may have to reinforce the nose some how (I personally would probably use biaxial fiberglass matting glassed onto the inside to reinforce the plastic nose).
IMV, the opening in the nose isn't really the problem, it's what's behind it (a bigass metal bumper) that blocks the flow of air to the radiator in an intercooled FI setup.
Ok that makes sense now, I looked all over the website as well...they definitely have what appears to be some fine quality products with a price tag to go along lol. That pic you posted the bumper is sick....I’d like to find a place locally that could do that to mine!
FYI for people interested, I ran this with no bumper support. The fiberglass is stiff enough to support the wind speed. I measured enough room to fit a 3" thick intercooler in front of the bumper crash bar. 31" wide gave plenty of room on the sides to direct air to the radiator. Fog holes fit a B&M oil cooler perfectly. Was a great set up for boosted applications.
Bluewheelz (06-28-2019)
That bumper looks familiar, hope its working out.
#33
#34
I apologize but I will not give out the name to where I bought this. He was local but nothing but problems. He has screwed a few people over and has gone MIA recently. I know supervettes can order it but quoted $3000. There is a company in SW Florida but never used them. These won't fit great to start, plan to out in some time to make then work right.
I might try to visit TIKT next week, as I’m in Munich now on holiday and will be driving to Salzburg then, and Stephanskirchen is just off the autobahn on the way there. If I do go, I’ll ask them about the nose on their C6 and post back on here whatever I can find out. They have some other awesome looking products that I want to look at as well, like their uni-ball suspension bushings.
CI GS (07-02-2019)
#36
#37
#38
I think removing the heat might be more important - a true vented hood like the C6R might work better than cutting up the bumper. It'll also create a little downforce too.
CI GS (07-02-2019)
#39
However, to maximise them you would want to lean the rad forward and build a proper ducted exit. This isn’t easy and you could easily make things worse without knowing by making the duct or small or ineffective.
Also a lot of people with FI would need big changes to the layout of their systems adding more cost / complexity.
So yeah ideally you would lay the rad forward but I don’t think it’s thats straight forward on a boosted C6. Maybe this bumper could be the ‘tiger shark’ (from the C5) for the C6!
CI GS (07-02-2019)
#40
Getting the air out will always help! But there is only so much you can do unless you want to get extreme! Hood vents will help and have been tried and tested.
