ECS used Tensioner damaged?
I bought a used ECS 1500 kit. I started going through the parts and noticed the tensioner appears to be damaged. It looks like the casting is broke by the spring. Also, the pulley has a groove in it...
Is this normal or did i get a bad part?
Also, What is the difference in the OD tensioner vs the standard?
Yes the bottom part is broken, and the pulley hit the balancer and messed it up. All of that of that needs to be replaced.
OD tensioner bracket is just a different mounting bracket so when the belt breaks it doesn't slam into the balancer like the one you have did.
DOUG @ ECS (06-04-2019)
Premium Supporting Vendor
Location: Providing the most proven supercharger kits for your C5/6/7 609-752-0321
Received 1,082 Likes
Thank you sir! OP, every piece of the kit can be purchased individually on our site www.eastcoastsupercharging.com
__________________
C5/C6 and C7 Supercharging Specialist
ECS Supercharger Kits / Mantic Clutches
www.EastCoastSupercharging.com
Facebook Page
ECS YouTube Channel
Facebook Page
ECS YouTube Channel
Thank you, that makes sense. Guess its a good thing i got a good deal on this kit...
I have spares in my garage. If you were local I would say swing by and grab one.
I appreciate the offer. I need the OD brackets as well so i will just order one from ECS... along with all the other parts i still need. Here's to opening up the can or worms that i said I would never do again... haha
