C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Centri blower belts...my experience..
Old 06-29-2019, 10:18 AM
harleyreb1
CF Senior Member
harleyreb1's Avatar
Seeing that bolt break(what grade bolt was it?) Iíd suspect to much belt tension. Just my initial thoughts.
harleyreb1 is online now
Old 06-29-2019, 11:27 AM
73DBG
CF Senior Member
Support Corvetteforum!
73DBG's Avatar
Not sure on the grade man, whatever comes with ProChargers kit I guess. To much tension would be surprising though since I had less tension with the new belt and both hash marked were lined up perfectly if you look at the pictures I posted earlier. I mean I guess itís definitely possible since I did my own work and Iím definitely no where near a professional. Not sure if a higher grade bolt would have been better or worse though.
73DBG is offline
Old 06-30-2019, 11:50 AM
GX427
CF Senior Member
Hope you get it back up and dyno’d soon looking forwards to those weak numbers
GX427 is offline
Old 06-30-2019, 12:33 PM
Unreal
CF Senior Member
Unreal's Avatar
Received 1,475 Likes on 1,253 Posts
Bolts break from them loosening or backing out. Then the stress goes into the bolt instead of the bracket. I would bet the bolt was backing out.
Unreal is offline
Old 06-30-2019, 01:32 PM
73DBG
CF Senior Member
73DBG's Avatar
Kinda what I was thinking the way it broke and that it needed just enough rpm to torque it enough at an angle to snap it, now why it backed out? How to prevent it again? Or how to check it in the future Iíd need some insight from you on that....or it just is what it is....**** happens, bolts back out
73DBG is offline
Old 06-30-2019, 02:38 PM
Unreal
CF Senior Member
Unreal's Avatar
Locktite and regular checks. Go over them all every oil change or so.
Unreal is offline
Quick Reply: Centri blower belts...my experience..
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
