Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C6 Corvette, 2005 - 2013 > C6 Forced Induction/Nitrous
Reload this Page >
Turbo feed and return using oil cooler no drilling the pan
C6 Forced Induction/Nitrous C6 Corvette Turbochargers, Superchargers, Pulley Upgrades, Intercoolers, Wet and Dry Nitrous Injection, Meth
Old 07-07-2019, 04:28 PM
gpargament
Junior Member
Default Turbo feed and return using oil cooler no drilling the pan
I have broken down my 07 c6z and im about to install the on3 twin turbo kit, after reading some of the other on3 installs i ordered a scavenge pump.
My question, could i run the oil cooler inlet line to a t fitting and then to both turbos? then use a scavenge pump and another t fitting for the return lines and send that to the oil cooler inlet, while leaving the oil cooler outlet going to the oil pan?
Basically i want to use a scavenge pump and install the turbo lines within the oil cooler feed loop.
This would also remove the need to drill the oil pan, thank you in advance for any help with this
gpargament is offline
Old 07-07-2019, 06:04 PM
Unreal
CF Senior Member
Unreal's Avatar
Received 1,475 Likes on 1,253 Posts
I don't see how that would work. The oil cooler lines are both pressurized, and you need to pump into a non pressure area.
Unreal is offline
Old 07-07-2019, 08:08 PM
gpargament
Junior Member
Daaang i guess drilling into the pan it is
Old 07-08-2019, 08:55 AM
jayyyw
CF Senior Member
You can plumb the return to the oil cap, with the scavenge pump.
jayyyw is offline
Old 07-08-2019, 09:55 AM
gpargament
Junior Member
Ohhhh wow that is a phenomenal idea
Old 07-08-2019, 10:18 AM
Unreal
CF Senior Member
Unreal's Avatar
Or a valve cover is common too.
Unreal is offline
Quick Reply: Turbo feed and return using oil cooler no drilling the pan
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
