LG tune with c6 automatic
I plan on going out to LG Monday to talk a bout tune and would like to see if anybody running a C6 2008 with Auto trans has had the TM turned off and what issues they had if or when it was done.
Upshift - controls TM on the upshift
Power downshift - controls TM on heavy throttle downshift
CT (closed throttle) downshift - controls TM when downshifting with your foot off the throttle
Garage shift - controls TM when shifting between gears, for example, from Park to Drive, Drive to Reverse etc.
Hope this helps.
The different parameters are:
Hope this helps.
Hope this helps.
Hope this helps.
Hope this helps.
plus they are in my back yard thanks.
How is a mail order tune from LG? Anyone have them do it?
This helps. can you tell me what is keeping the power or torq from coming on at lower RPM. something in the system is keeping torq down until either the clutch in the auto trans are full engaged or it feels this way. up in the rpm range it really seems to turn things loose. what is keeping it down in the program if not TM.
I had my shift points changed when I had my car tuned. My car now shifts at about 2000 rpm in all gears. The car now cruises at around 1500-1800 rpm. When I jump on it, the car is more in the power band of the rpm range, giving me less of a hesitation, and instant power.
Have both your car and tranny tuned and it will feel like a different car.
