C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
I need help! 2006 corvette c6 ls2 engine sound noise
Old 04-12-2012, 09:25 PM
SaiBeeC6
4th Gear
SaiBeeC6's Avatar
Default I need help! 2006 corvette c6 ls2 engine sound noise
I have a 2006 C6 LS2 motor with 50k 6 SPEED
Recently this sound coming from the engine.(whining, creaking)
http://www.youtube.com/watch?v=JLowo...ature=youtu.be
Anybody know what should i do first?
NO CHECK ENGINE LIGHT, engine run strong.
Old 04-13-2012, 03:17 PM
TNTC4VETTE
Will work for HPDE time.
Support Corvetteforum!
TNTC4VETTE's Avatar
Sounds like the balancer's going out and you have an exhaust leak.
Old 04-13-2012, 03:34 PM
pit-man
pit-man's Avatar
I presume u know it isn't the belt chirping ? You can squirt a litttle shot or two of wd-40 on the underside of the belt to check. It would stop making noise for a little while.
Old 04-13-2012, 07:44 PM
SaiBeeC6
4th Gear
SaiBeeC6's Avatar
Thank you for the fast response!
But the balancer was change 5000 miles ago because it was wobbling.....
I also tried spraying some wd-40 on the underside of the belt but the sound is still there.... did not even go away
What else you guys think it is?
Can it be the lifters? camshaft?
Or is there anyway i can check if the balancer going out?
Old 04-13-2012, 08:24 PM
txvettefan
txvettefan's Avatar
Remove your belt(s) and start your engine. By doing so you will have isolated the engine from the accessories.
Old 04-13-2012, 09:10 PM
cryoman07
cryoman07's Avatar
New to vettes. But when a spun a cam bearing in the stang sounds similar
Old 04-13-2012, 11:58 PM
jimmyb496
jimmyb496's Avatar
Start here to rule some possibilities out.
Old 04-18-2012, 10:46 AM
SaiBeeC6
4th Gear
SaiBeeC6's Avatar
Removed both belts, Start the engine. the sound is still there.
Can it really be my lifters? or camshaft? or what else should i try?
any answer is very appreciated, thank you
Old 04-18-2012, 11:00 AM
txvettefan
txvettefan's Avatar
Please do not shoot the messenger:
I strong suspect that you've incured a classic LS2 Oil Pump Failure and SMOKED THE CAM BEARINGS!
The exact thing happened to me in my 06 GTO.
Old 04-18-2012, 11:06 AM
txvettefan
txvettefan's Avatar
Your really need to pull the engine, because your rod and main bearing get priority oiling and I strongly suspect that you may have a bad rod bearing(s).
All is not lost: the rods can be resized, ARP 2000 series rods bolts, regrind the crank, & balance the rotating assembly or
HAVE A MYSTERIOUS FUEL PRESSURE LEAK >>>>>STARTS A FIRE>>>>>>>>>>CALL ALLSTATE!!!!
It is not the end of the world!!!
Old 01-12-2014, 11:08 AM
Educ6
4th Gear
Educ6's Avatar
Hello
I write from Spain,
I just like the sound, I have the same problem in 2007 LS2 vette
thanks
Old 01-12-2014, 11:11 AM
Educ6
4th Gear
Educ6's Avatar
Hello
I write from Spain,
as I finish?, I have the same problem in 2007 LS2 vette
Thanks for your help
Old 01-12-2014, 02:37 PM
subfloor@centurytrans
Supporting Vendor
subfloor@centurytrans's Avatar
2020 Corvette of the Year Finalist (track prepared)
C6 of Year Winner (track prepared) 2019
Unfortunately you've almost certainly got a lifter stuck in one of the lifter bores. The same thing happened to me a few years ago:
The good news is that you might not to need to tear down the entire engine to fix it. In my case, what happened was the little pin holding the roller in the lifter started moving sideways which restricted it's movement in the bore. The roller got flattened but the cam itself was still fine. Getting the lifter out was quite a challenge however but still doable.
Old 01-12-2014, 05:06 PM
Educ6
4th Gear
Educ6's Avatar
hello! Thanks for your support! I do not understand English I use google translator. Live in Spain
Is this what you get stuck??
thank you very much
Old 01-13-2014, 12:45 AM
SaiBeeC6
4th Gear
SaiBeeC6's Avatar
thank you very much
Yes it was my lifters, changed out my lifters and sound was gone.
Old 04-04-2014, 12:04 AM
C6Rdstr
3rd Gear
C6Rdstr's Avatar
Possibly a bad A/C condenser bearing. My 05 C6 6MT had this noise problem and had the dealer replace my condenser and noise went away.
Old 04-04-2014, 12:17 AM
Supporting Vendor
A condenser has no moving parts.
To I need help! 2006 corvette c6 ls2 engine sound noise
Old 04-04-2014, 07:21 AM
tennblkc6
tennblkc6's Avatar
wow...hope you at least got a reach around with that repair.
Old 04-04-2014, 05:37 PM
C6Rdstr
3rd Gear
C6Rdstr's Avatar
I'm sorry, I meant A/C compressor.
Old 04-13-2014, 12:43 PM
majorpayne317641
majorpayne317641's Avatar
Do you rev or drive aggressive? Any mods done to the car? Does is start slower than normal or studder before starting at times? Pull the timing cover and check the bolts on the cam sprocket, I had all 3 back out, one was grinding on the cover and broke off, I did have the cam position error code after a few starts.
Quick Reply: I need help! 2006 corvette c6 ls2 engine sound noise
