My quick vitesse throttle control review
I just installed mine, it took about 10 minutes, super easy install.
WOW!!! Not only is it incredibly responsive, the car feels faster and feels like I added a set of 411 gears. Until you have one, you won't know.
If I had to choose between a tune or the throttle control as my first mod? I would pick the throttle control hands down. "Buy it" and fall in love with your vette all over again.
Here's the link It's only a $179 and it has like 15 separate positions too!
http://vitesse-motorsports.com/throt...orvette-c6.htm
Tim
Tim
I bought mine a while ago but didnt install it before I sent my car to get a sc installed. I wonder if I need to hold off on this or if I should install it once I get the car back... glad to see another success install.
Omg for 179$ the best money ever spent on my Vette. It changed the way the transmission shifts, stays in lower gears longer... Feels like I added a stall convertor to it because of the way it lights up the tires and gets the turbos spinning.
Big grins
Big grins
I wonder if this box is loading different transmission settings to the tune file?
Depending on the setting it's just making the throttle opening more aggressive, which in turn affects when the transmission downshifts, based on the throttle % open. The OEM throttle programming is non-linear, with the throttle only open about 20% when you have the gas pedal 50% to the floor. The Vitesse makes gives the throttle a more linear response, like a cable-driven throttle.
Received 1,194 Likes
St. Jude Donor '15
I completely agree that the car feels faster when you press the gas pedal 20% down and get 40% throttle opening instead of 20% throttle opening (not real numbers, simply an example), but that also means you have less precise control over the throttle since less movement = more opening. It should also be noted that the gas pedal in stock form is capable of opening the throttle to 100%, and this device will not change that. I just want it to be clear to any reading that it does not increase acceleration like adding 50hp or 4.11 gears, only perception because you are accustomed to the stock throttle curve.
Anyway I'm sure my post sounds like a broken record on this topic. I'm not trying to flame or shoot someone down, again my point is to be clear about what these throttle control modules do. I'll leave it at that.
zras01 (05-19-2016)
I don't know if he does or not, but I do... and he is 100% correct about the "doesn't add 50hp" or better gearing or transmission tuning.
I like the product... I have it installed on my SC'd C6 in my sig. It helps tip-in throttle response for sure. You do get to 100% quicker (and every % of WOT, for that matter) ... so, in theory, if you and another car making the _same_ HP did an acceleration pull, you would be quicker b/c you get to WOT faster (a split second faster).
The great thing is that the driver can tailor it to his/her own sensitivity level. I started at SP6 b/c many others have reported that to be a good setting, but I backed it down to SP4... probably b/c I have a modded car, and it seems to work well with my right foot ... and does seem to be more linear like a throttle cable activated setup.
But it does NOT increase horsepower... Vitesse doesn't claim that it does.
It's definitely a great product, and I would recommend it...especially for those who have experience with cable-drive throttle controlled hot-rods and feel the DBW set up is "lazy and unresponsive" at tip-in.
Lol I think I know where you were going with that question - doubt it had much to do with asking for my review of the product. I do not have one on my Z06, but that doesn't mean I can't speak on the subject. These things have been out for years under many different names and I owned one for one of my ricer mobiles in the past (that one was called the "Sprint Booster"). As I said in my previous post, it does make your car feel faster. There is however no quantifiable improvement in acceleration or power.
I was asking because I've seen several posts from people who have tried similar products and although this performs a similar function, this one consistently gets the highest feedback. It's good that you used a sprint booster so you'd have an idea of the differences. I think if you tried one, you'd be surprised. I'm just saying others have, you might too.
I can't say that I agree with you about your last sentence. While there might not be a significant improvement in acceleration, I feel there most certainly is one....even if only measured in minute increments. If getting up in the RPM higher range sooner had no benefit, why would one use a stall converter (as an example)?
But!! on the 1/8 dragstrip and I believe in the 1/4 mile as well.
if the throttle ramps up quicker, you'll get out there faster and will have faster times. Because of the well known throttle lag it will take you longer to come up to speed from a dead stop! If I race someone and he gets out on me by a couple of cars with the same horsepower I will never catch him! I lose! When the race is viewed by spectators!
Ask them who won the race? Ask them who's car was faster?
Just like two identical cars race. one has 323 rear end gears the other with 411s or 456s same horse power, but the guy with the higher gears is going to win every time! I don't know why he keeps bringing up the horsepower. Do you think everyone is stupid? Or you just trying to show everybody how smart you think you are?
Quit beating a dead horse!
I think the key words are "feels like"...meaning there was a perceived improvment. It was not meant as an indication that the product adds anything. I really don't see a need to quantify that, as if one thought a box can change your gear ratio then wow.
I have never felt like the pedal in any C5 or C6 corvette is linear from the factory, I would love to see its pedal position vs commanded but I have yet to have time to look into it.
Controller eliminated nanny controlled lag hesitation and increased throttle response - best first mod for $179. My A6 sprints much better now.
Maybe COW gets your there, but I'd rather have a device that allows me full control that doesn't touch the ECU.
St. Jude Donor '15
There wasn't a unit available for any 2005's last I checked
