Procharger Dyno Tune/Diablosport intune i2
I searched the forums and found many similar topics, but an answer to my question wasn't quite clear. I have a procharger installed. It's been tuned using Diablosport, but I don't have a Diablosport tuner in my area. If I have my car properly dyno tuned with hptuners or another software could I then make small WOT fuel adjustments using my intune i2 or would I then have to always use that particular software?
For the small time that I experimented with a Diablosport I2, I am not sure this platform gives you the capability to make changes to the PE tables, but I don't know the capabilities of that platform enough to say. Maybe a DS 1000, but I don't think the I2 can?
The diablos/scts/etc all lock the system down. They need to be married to the car. So until you over write the HP tune with a diablo tune, it won't allow you to change anything.
Sell the diablo and get HP.
Supporting Vendor
There are however things that we do differently on the E92 which can cause no start issues if you flash with one over the other after starting with a read of the other. My advice would be to not attempt what you have asked OP, although that process does work fine on the earlier E38 cars.
Not locked per say how HP does it, but it every handheld I've seen does things that make then editing with HP/EFI after not possible.
Good to know that it might work on an e38. I know with my SCT cars I can't read the files from HP tuners.
