SCT X4 with FREE Custom Tuning @ RDP Store..... - Page 12 - CorvetteForum - Chevrolet Corvette Forum Discussion
Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C6 Corvette, 2005 - 2013 > C6 Scan & Tune
Reload this Page >
C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Old 11-11-2018, 07:51 PM
  #221
RDP Store
Supporting Vendor
RDP Store's Avatar
Pm us for a Price on any Part Number your Looking at.
RDP Store is offline
Old 11-12-2018, 06:56 PM
  #222
RDP Store
Supporting Vendor
RDP Store's Avatar
The title says it all, FREE true custom tuning for your C5/C6/C7 Corvette. With the purchase of our Tuner Package which includes the SCT X4 and Custom Tunes for life as long as you own you Corvette all for the amazing value of $419.oo with FREE same day shipping to your door
http://rdpstore.com/p-6042-tuner-kit...ierra-gmc.aspx
So what is a Custom Tune? Well it is NOT a preloaded tune that will find on your SCT X4 programmer when it shows up at your doors step. Our Custom Tuning @ RDP Store is the closest you can get without having your car on a dyno. With our years of GM tuning experience we can tune your car remotely (via email) based on the modifications you have, the type of fuel you are running, the area you live, type of driving style you have and much more.
Stay tuned to this thread for an overview on what this very simple and extremely effective process this is. This is the single best modification you can do to you Corvette. It is the foundation of all your modifications to come. For now lets take a look at the very powerful SCT X4............
Below is a over view of the System.
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
Old 11-13-2018, 12:42 PM
  #223
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 11-13-2018, 12:43 PM
  #224
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 11-14-2018, 05:42 PM
  #225
RDP Store
Supporting Vendor
RDP Store's Avatar
PM us for a Black Friday / Cyber Monday Deal Promo Code.
Old 11-15-2018, 04:00 PM
  #226
RDP Store
Supporting Vendor
RDP Store's Avatar
Online Store Now Accepts all Credit Cards and Paypal Payments and Also has Paypal Financing Options and we Ship Worldwide with Cost Price Shipping.
Old 11-17-2018, 09:19 PM
  #227
RDP Store
Supporting Vendor
RDP Store's Avatar
Use our Promo Code and save
Old 11-19-2018, 11:36 AM
  #228
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 11-19-2018, 07:40 PM
  #229
RDP Store
Supporting Vendor
RDP Store's Avatar
Thanks for all the pm's guys
Old 11-20-2018, 07:14 PM
  #230
RDP Store
Supporting Vendor
RDP Store's Avatar
all pm's sent
Old 11-25-2018, 06:15 PM
  #231
RDP Store
Supporting Vendor
RDP Store's Avatar
Great Time to your corvette tuned after some black friday performance upgrades
Old 11-26-2018, 08:40 PM
  #232
RDP Store
Supporting Vendor
RDP Store's Avatar
Last Days get in Now and SAVE SAVE SAVE $$$$$$$$$$
Old 11-28-2018, 03:52 PM
  #233
RDP Store
Supporting Vendor
RDP Store's Avatar
We wont be beaten by any competitor and we also offer discounted installation rates as well
Old 11-29-2018, 12:09 PM
  #234
RDP Store
Supporting Vendor
RDP Store's Avatar
in stock for immediate shipping
Old 11-30-2018, 05:16 PM
  #235
RDP Store
Supporting Vendor
RDP Store's Avatar
Black Friday / Cyber Monday Sales Extended until Midnight Sunday
Old 12-01-2018, 08:06 PM
  #236
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store has teamed up with Paypal to Offer 6 Months Interest Free Finance on all items over $99, its a simply process and only takes a couple of minutes to complete on the Site
http://www.rdpstore.comAttached Images
Old 12-07-2018, 02:28 PM
  #237
RDP Store
Supporting Vendor
RDP Store's Avatar
Due to SCT's Legal Issues with the EPA alot of Tuning Parameters are going to be deleted from the software from January 2nd, this will effect header installations Fuel System upgrades Supercharging etc, if you currently have mods and wanting to get them fitted and tuned and programmers bought this needs to be done before 30th of December this Year, PM me or give me a call on 440 358 5500 for more information.
Old 12-11-2018, 04:20 PM
  #238
RDP Store
Supporting Vendor
RDP Store's Avatar
Great Christmas Deals re Currently Running with End of Year Savings and Free Shipping to the Lower 48 States and Cost Price Shipping anywhere else in the World.
Old 12-12-2018, 11:31 AM
  #239
RDP Store
Supporting Vendor
RDP Store's Avatar
Thankyou for all the PM's and Questions and Orders we Greatly Appreciate your Business.
Old Yesterday, 04:19 PM
  #240
RDP Store
Supporting Vendor
RDP Store's Avatar
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
Quick Reply: SCT X4 with FREE Custom Tuning @ RDP Store.....
Sponsored Ads
Vendor Directory
Contact Us About Us Archive Advertising Cookie Policy Privacy Statement Terms of Service
© 2018 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
