SCT X4 with FREE Custom Tuning @ RDP Store.....
#281
Supporting Vendor
Its the Winter Make us a Deal Program, Simply Look up the Part you want and Need and let us know and we will Put together a Winter Saving Deal for you, Also Doesnt matter if you dont see it on our website as we still probably have it and havent added it to the site yet, Either pm us here or give us a call on 440 358 5500 www.rdpstore.com
#282
Supporting Vendor
Benefits of Buying your Performance Parts from RDP Store
1. We are a Direct Dealer for the Manufacturers
2. Full Manufacturer Warranty
3. We Offer 6 Months Interest Free
4. Easy Payment Options, Visa Mastercard Amex Discover Paypal etc
5. Free Shipping to the Lower 48 States
6. Cost Price Shipping Anywhere in the World
7. Same Day Shipping on Any in Stock Item Before 7pm EST
8. Live Tracking Information
9. 24hour a Day 7 Day a Week Live Chat Service
10. True Tech Support for People that Install and Tune the Parts we Sell
11. Price Match Gaurentee on All Items that We Stock and Sell
12. Special RDP Store Member and Forum Member Discounts
13. NO Upsell /Snake Oil Selling, We will Only Sell you something if it Works!
14. 365 Day a Year 24 Hour a Day Online Store with Easy Shopping
Experience.
For More Information on the Part you Need and Advise on what works and whats doesnt and a Special Price with the above benefits, PM us Here or give us a Call Directly on 440 358 55000 or Jump onto our Online Store at http://www.rdpstore.com
Experience.
#283
Supporting Vendor
The title says it all, FREE true custom tuning for your C5/C6/C7 Corvette. With the purchase of our Tuner Package which includes the SCT X4 and Custom Tunes for life as long as you own you Corvette all for the amazing value of $419.oo with FREE same day shipping to your door
http://rdpstore.com/p-6042-tuner-kit...ierra-gmc.aspx
So what is a Custom Tune? Well it is NOT a preloaded tune that will find on your SCT X4 programmer when it shows up at your doors step. Our Custom Tuning @ RDP Store is the closest you can get without having your car on a dyno. With our years of GM tuning experience we can tune your car remotely (via email) based on the modifications you have, the type of fuel you are running, the area you live, type of driving style you have and much more.
Stay tuned to this thread for an overview on what this very simple and extremely effective process this is. This is the single best modification you can do to you Corvette. It is the foundation of all your modifications to come. For now lets take a look at the very powerful SCT X4............
Below is a over view of the System.
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLYAttached Images
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
#284
Supporting Vendor
With Tax Season upon us and some extra cash to spend on your toys, pm us for a Special Deal on any item that your looking at and we can get you hooked up, we will match and Beat any Genuine Quote and we have 6 Months Interest Free Options and Layaway programs. Give us a call on 440-358-5500 or email us at sales@rdpstore.com
#285
Supporting Vendor
RDP Store has teamed up with Paypal to Offer 6 Months Interest Free Finance on all items over $99, its a simply process and only takes a couple of minutes to complete on the Site
#286
Supporting Vendor
RDP Store is Proud to Offer a Complete Range of Performance Parts and Accessories to the Forum Members Here at Special Forum Member Pricing with Heavy Discounts, Our pricing structure saves you the forum member alot of $$$ and there is no waiting for items to ship, we also ship for Free to the Lower 48 States and Cost price shipping any where else in the World.
We make sure at any time you know where your order is and supply tracking information and Email and Phone Support for any questions that you may have.
We Not only Offer Special Pricing on Performance Parts and Accessories but we also Offer a Remote Tuning Option as well to dial in all your New found Power and Performance whilst making the vehicle alot more fun to drive and under normal driving conditions help improve your economy as well.
For More Information PM us here or Give us a call on 440 358 5500 or 440 251 8571
http://www.rdpstore.comAttached Images
#287
Supporting Vendor
We wont be beaten by any competitor and we also offer discounted installation rates as well
#288
Supporting Vendor
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
#289
Supporting Vendor
#290
Supporting Vendor
#291
Supporting Vendor
Real Deals for Proven Performance Items that we install and dyno tune on a Daily Basis and NOT just do Internet Parts Sales with my True World Knowledge and Tech Support. Pm us with any questions for your Application and for a Forum Members Discount.
#292
Supporting Vendor
#293
Supporting Vendor
Experience.
Experience.
#294
Supporting Vendor
We wont be Beaten By ANY Competitor on Pricing and Service Put us to the Test on Any Item that we Stock and Sell
#295
Supporting Vendor
We wont be beaten by any competitor and we also offer discounted installation rates as well, and all products we sell come with Full Manufacturer Warranties Unlike items Sold on Amazon and Ebay.
#296
Supporting Vendor
Thankyou for all the Orders Everyone one we Greatly Appreciate your Business.
#297
Supporting Vendor
Get Ready for Spring with Summer Savings on Everything you Need.
#298
Supporting Vendor
No Better Time than the Present to Save on those items that you have been wanting to get and be ready for Spring.
#299
Supporting Vendor
great time of the year to get tuned
#300
Supporting Vendor
