Go Back  CorvetteForum - Chevrolet Corvette Forum Discussion > C6 Corvette, 2005 - 2013 > C6 Scan & Tune
Reload this Page >
SCT X4 with FREE Custom Tuning @ RDP Store.....
C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
Old 02-20-2019, 07:32 AM
  #301
RDP Store
Supporting Vendor
RDP Store's Avatar
The title says it all, FREE true custom tuning for your C5/C6/C7 Corvette. With the purchase of our Tuner Package which includes the SCT X4 and Custom Tunes for life as long as you own you Corvette all for the amazing value of $449.oo with FREE same day shipping to your door
http://rdpstore.com/p-6042-tuner-kit...ierra-gmc.aspx
So what is a Custom Tune? Well it is NOT a preloaded tune that will find on your SCT X4 programmer when it shows up at your doors step. Our Custom Tuning @ RDP Store is the closest you can get without having your car on a dyno. With our years of GM tuning experience we can tune your car remotely (via email) based on the modifications you have, the type of fuel you are running, the area you live, type of driving style you have and much more.
Stay tuned to this thread for an overview on what this very simple and extremely effective process this is. This is the single best modification you can do to you Corvette. It is the foundation of all your modifications to come. For now lets take a look at the very powerful SCT X4............
Below is a over view of the System.
Stores up to 10 custom tune files created by your local SCT Custom Tuning Dealer.
High Speed Datalogging / Monitoring
View & record your vehicles PCM data on the LCD screen or on your laptop.
Easy Restoration Back to Stock
The X4 Flash device backs up your factory PCM program during installation should you ever need to return your vehicle to the stock program. Restoring your vehicle to the stock PCM program is as easy as selecting "Return to Stock" from the device menu. With all SCT devices, once returned to stock, there is no footprint or trace of the tune in the vehicle's PCM.
Most Popular Vehicles Supported
Most popular GM vehicles supported
USB Interface Cable Included
USB Interface Cable & Livelink Datalogging software included
Built-In Wifi for easy updates
Built-in Wifi allows you to easily attach to your local area wireless
* Adjustable Options vary for each vehicle and are not available on all vehicles
Rear O2's Disabled
Disables the Rear O2s and eliminates CEL caused by rear O2 removal.
Fuel Injectors
Allows you to adjust for different sized fuel injectors.
CMCV Delete Plates
Allows you to disable the CMCV (Charge Motion Control Valve) in your vehicles PCM to prevent a Check Engine light and other issues associated with removing the CMCV plates in your vehicle.
Speed Limiter
Allows you to Remove, Increase or Decrease the vehicles speed limiter.
Idle Speed
Allows you to Increase or Decrease the vehicles idle speed.
Traction Control
Allows you to disable the vehicles Traction Control without using the button in the vehicle.
Spark Modification by RPM
Allows you to Add or Remove Timing by RPM Range. (0-2000)(2000-4000)(4000-8000)
WOT Fuel
Allows you to Add or Remove Fuel at Wide Open Throttle.
Shift Firmness Control
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLY
Axle Ratio
Allow you to set the axle ratio (gear ratio) to correct shift patterns and the speedometer on your vehicle.
Tire Size
Allows you to set the tire size to correct shift patterns and the speedometer on your vehicle.
Aftermarket Intake
Allows an aftermarket intake to be run on the vehicle without a Check Engine Light. For Intake Kits that require tuning, this will provide a selection of available intake kits.
Stores Stock Tune
Stores a true copy of your vehicle's stock file before programming. Used for warranty repairs and unlocking the programmer.
Supports Custom Tunes
Supports and holds custom tunes.
Fan Control
Lowers the Temperature at which the Fan turns on.
Idle Speed
Rev / RPM Limiter in Drive
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Drive
Rev / RPM Limiter Neutral
Allows you to Remove, Increase or Decrease the vehicles Rev / RPM limiter in Neutral
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
WOT Shift Points by Gear
Allows you to Increase or Decrease the Wide Open Throttle Shift points of each gear individually.
RDP Store is offline
Old 02-21-2019, 10:21 AM
  #302
RDP Store
Supporting Vendor
RDP Store's Avatar
Spring is just around the corner and with tax return time here theres no better time to get those items your wanting for your ride, pm us for a special deal or give us a call on 440-358-5500
Old 02-22-2019, 08:22 AM
  #303
RDP Store
Supporting Vendor
RDP Store's Avatar
PM Us for a Deal to Beat ALL Others. We Will Match and Beat ANY Competitor that is Not of a DO NOT Sell List from the Manufacturer
Old 02-23-2019, 08:41 PM
  #304
RDP Store
Supporting Vendor
RDP Store's Avatar
Thankyou to All our Wonderful Customers for your Orders and Inquiries and we look forward to working with you all through this 2019 season.
Old 02-25-2019, 07:19 PM
  #305
RDP Store
Supporting Vendor
RDP Store's Avatar
We wont be beaten by any competitor and we also offer discounted installation rates as well, and all products we sell come with Full Manufacturer Warranties
Old 02-26-2019, 12:17 PM
  #306
RDP Store
Supporting Vendor
RDP Store's Avatar
Deal with the Guys that Not only sell the parts but install tune and race them on our own cars
Old 02-27-2019, 05:54 PM
  #307
RDP Store
Supporting Vendor
RDP Store's Avatar
Rear O2's Disabled
Fuel Injectors
CMCV Delete Plates
Speed Limiter
Idle Speed
Traction Control
WOT Fuel
Axle Ratio
Tire Size
Aftermarket Intake
Stores Stock Tune
Fan Control
Idle Speed
Speed Limiter
Fan Control
WOT Fuel
Axle Ratio
Tire Size
Allows you to change the transmissions shift pressure. Controls how firm the shifts will feel. * Vehicles with Automatic Transmissions ONLYAttached Images
Old 03-01-2019, 08:30 PM
  #308
RDP Store
Supporting Vendor
RDP Store's Avatar
RDP Store has teamed up with Paypal to Offer 6 Months Interest Free Finance on all items over $99, its a simply process and only takes a couple of minutes to complete on the Site Also Save Everyday with RDP Store Member Pricing
http://www.rdpstore.com
Old 03-02-2019, 01:42 PM
  #309
RDP Store
Supporting Vendor
RDP Store's Avatar
PM for deals and Benefits
Old 03-03-2019, 05:56 PM
  #310
RDP Store
Supporting Vendor
RDP Store's Avatar
We wont be beaten by any competitor and we also offer discounted installation rates as well, and all products we sell come with Full Manufacturer Warranties Unlike items Sold on Amazon and Ebay.
Old 03-04-2019, 08:26 PM
  #311
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 03-05-2019, 06:44 PM
  #312
RDP Store
Supporting Vendor
RDP Store's Avatar
With Tax Season upon us and some extra cash to spend on your toys, pm us for a Special Deal on any item that your looking at and we can get you hooked up, we will match and Beat any Genuine Quote and we have 6 Months Interest Free Options and Layaway programs. Give us a call on 440-358-5500 or email us at [email protected]
Old 03-06-2019, 06:37 PM
  #313
RDP Store
Supporting Vendor
RDP Store's Avatar
Put those Tax Return Dollars to good use and buy your car something to make you both Happy!!!!
Old 03-08-2019, 10:50 PM
  #314
RDP Store
Supporting Vendor
RDP Store's Avatar
Bump for a Deal
Old 03-10-2019, 02:14 PM
  #315
RDP Store
Supporting Vendor
RDP Store's Avatar
The title says it all, FREE true custom tuning for your C5/C6/C7 Corvette. With the purchase of our Tuner Package which includes the SCT X4 and Free Custom Tunes for life as long as you own you Corvette all for the amazing value of $449.oo with FREE same day shipping to your door
http://www.rdpstore.com/p-6042-sct-x...tom-tunes.aspx
Old 03-12-2019, 08:00 PM
  #316
RDP Store
Supporting Vendor
RDP Store's Avatar
In Stock for Immediate Free Shipping
Old 03-13-2019, 06:52 PM
  #317
RDP Store
Supporting Vendor
RDP Store's Avatar
Great Time of the Year to get the Mods started
Old 03-15-2019, 09:45 AM
  #318
RDP Store
Supporting Vendor
RDP Store's Avatar
Best Pricing and Best Service to the Forum Members here, hit us up with questions and for a Promo Code.
Old 03-16-2019, 07:16 PM
  #319
RDP Store
Supporting Vendor
RDP Store's Avatar
Old 03-17-2019, 02:34 PM
  #320
RDP Store
Supporting Vendor
RDP Store's Avatar
Quick Reply: SCT X4 with FREE Custom Tuning @ RDP Store.....
Sponsored Ads
Vendor Directory
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
  • Ask a Question
Question Title:
Description:
