engine light help
engine light help
hello again fellas
the ls2 still hasnt blown up, in spite of my efforts LOL...im glad its holding up as i save money for a new motor at least...tough little bastard
so i got some codes a couple i recognize but one i need help with
C0710 steering wheel position sensor...i know its bad cuz it fails the tech 2 test so im waiting on that
P0449 the rear solenoid valve... either bad solenoid,bad connector,cut wire or blown fuse... theres a jumper wire where the dipshit who owned it last did some shady **** to get it working or it was the dealer..i suspect the dealer
B2355 driver vertical position switch... i havent seen much of this code anywhere and wondering of someone has replaced this sensor and could help me locate it so i can replace it...or maybe its a connector.
as always thanks for the help guys......and gals if youre out there
ive been wondering about this...i would think the anser would be yes since the active handling woud use steering wheel position as part of its input ..
but would the malfunctioning steering wheel position sensor cause the servive active handling message to come on...it also causes the active handling(brakes) to come on
