2011 Grand Sport
Supporting Vendor
You can perform a few simple changes depending on your setup.
If manual transmission, then you can disable that annoying CAG's and if an Automatic, you can really improve the shift feel with a transmission tune update.
For the PCM you can do a few easy mods like reduce the amount of timing being pulled by the IAT (stay within reason like move 86F up to 113F) and PE EQ Ratio to a fixed 1.15/1.17 or lower the Fans to run a bit cooler which is more power.
We can help you with these easy changes as well as when you decide to install any modifications. We also offer tuning training if you would like to learn more details on the tuning process and strategies.
Good luck and happy tuning
Ed M
Ed M
__________________
Vette Doctors Performance aka The Vette Doctors
52 Elm Place, Amityville, NY 11701 info@thevettedoctors.com or http://www.thevettedoctors.com/
(631) 841-0779
Featuring EFI Live/HP Tuners Performance Tuning in-house or remotely and HP Tuner/EFI Live training by ERM Performance Tuning
www.ermperformancetuning.com
(631) 841-0779
