Injectors not firing
Just finished up the install on my Sniper intake and my left bank of injectors are not firing. Got the code, then checked each header pipe with a later temp gun and they all read room temp. Engine running rough, of course.
I checked and found the pigtail to #1 injector pinched between the coil bracket and the valve cover. Looked like no real damage to the wire, but being ****, I replaced the pigtail.
Is there a fuse that the pinched pigtail may have shorten and blown? I checked the top of the fuse box but found no help.
I'm stumped.
Suggestions????
Mb)
I'm stumped.
Suggestions????
Mb)
There are 2 fuses for the injectors, even and odd. Look in the fuse box and there will be a fuse marked INJ(even) and another INJ(odd). So you only lose half the injectors if something happens.
EuroRod (09-04-2017)
Next is a pulley downsize and a new tune.
Thanks again for your help.
