Help!! Rich idle and part throttle surge/bucking..
2011 superchargered corvette Problem with rich idle and part throttle surge/bucking.
I have a 2011 corvette GS with stock LS3 and A&A supercharger w/3.8 pulley, HPI 80lb injectors, TR6 plugs w/.35 gap, ZR1 map, Zo6 manifolds, X-pipe and mufflers. Other then that the car is stock.
Im still new to tuning and im working on the MAF only at this point. The car according to the WB is super rich at idle, but once im moving its good. i have a log ill post and the LTFT look good down low..The car also has a surge/buck around 1400-2100 rpm that im trying to figure out. i have a hot start issue as well that im chasing my tail on.
Included is a log of Part throttle and idle issues, current tune and injector data.
Here is a link to the hp tuners forums..the log is there, to big to post here..
https://www.hptuners.com/forum/showt...-surge-bucking
Thank you
Thank you
Thank you
Thank you
Why are you running 80# injectors on this combo? That's HUGE and completely unnecessary for your current power level. A set of smaller injectors will have MUCH better short pulse control (drive quality) and still be able to support the power level you're at. I'd strongly recommend looking at either the SD60's (for which I have published the characterization data in my EFI calibration training videos) or the ZIP products 60's (which also ship with the precise characterization data). This will make your life MUCH easier and give you better results overall.
