Safe to run stock intake on a tuned z06?
6th Gear
Hi, I recently purchased a z06 that was tuned with an airaid cold air intake, heads, and cam. The seller removed the airaid intake prior to the sale and put the stock intake back on. I am wondering if it is safe to run the car with the stock intake even though it is tuned for an aftermarket system. Any help would be greatly appreciated.
6th Gear
I have the receipt from the shop that did the initial mods and it was done by a reputable tuner. The car seems to run fine and I haven't gotten any CELs. I was curious because the Airaid does not require a tune for install, so it seems to make sense that removing it after a tune shouldn't affect anything either. I'm still new to these cars, but I thought the computer would adjust for the change in airflow.
I think you will be fine .......no retune necessary
Dave
Dave
St. Jude Donor '08
I think Dcasole has correctly answered your question about being "safe". But on a heads and cam 427, you might want to consider more as discussed by one of this forum's premier tuners in the below thread.
https://www.corvetteforum.com/forums...post1595711604
