Car will not communicate with smog equipment
Hi all. I took my 07 Z06 in to get it smogged in CA. Two locations were unable to get their equipment to communicate with the car. Only thing I did was reinsert the exh fuse. I have been driving it the last year without the fuse so the exhaust was louder. I put it back in just for the smog test. I have never had an issue with smog before. I Google the issue and checked the possible fuse culprits but they were all good. Wiring does not seem to be loose under the steering wheel. Ecm fuse is also good. Anyone out there have a solution???
Location: If you don't weigh in you don't wrestle Road America
Could they not connect with the ECM or was there no power at the ALDL connector?
If there is no power at the ALDL connector then I know you said you checked the fuses but I believe the cigar lighter fuse also powers the ALDL connector - check to make sure that fuse isn't blown.
Easy to do I have done it probably 15 times . only 2 screws need to be removed from the panel that has your fuel door and rear hatch switch on it, after removing the screws use a flat blade plastic pry tool to pop loose the clips on the left and right sides of the steering column. the previous panel has 2 tabs that go under the panel where your start button is on rt. side and dash light adjusting **** on the left side . This panel has to be popped loose and lifted in order to remove the panel below it. The panel near your pedals are just secured by 3 plastic fasteners.
Best if you remove the seat .
