Service Active Handling ?
I have a 2011 ZR1 and I have been doing some upgrades nothing that I know of that has t do with the Active Handling or traction control except I have had the console and the bezel around the Nav. unit and heater controls . So I had to disconnect the traction and active handling plugs but I checked to make sure they are still plugged in.
My traction control button turns it off and on but the traction control indicator light does not go off and the "Service Active Handling " message scrolls by.
I connected my Tech 2 and found no DTC codes in that area.
Why does it not throw a DTC code ? What could be the problem?
hitekcm is online now Report Post
I just got the same problem. I am going to follow. Two separate times I had the same spark plug wire come loose and arch on the manifold causing the problem but that is not my problem now.
My problem turned out to be the steering being off center. This trows off the active handling so if you did anything to the steering column that may be the problem.
I found out I have 3 codes
Steering position signal malfunction
Right rear speed sensor circuit open or shorted
Right front wheel wheel speed sensor circuit
you will need a Tech 2 to center the steering I don't think there is anyway to center it without a Tech 2. The tech 2 will tell you the degrees on the steering angle and you have to zero it you are probably negative or positive on the degrees.
A firend of mine who was a former Corvette mechanic said he has a Tech 2 and should be able to look at it this week hopefully.
Might be handy to have one of my own anyways. I will have to look into it. Thanks
My problem was the Vitrese control. My mechanic, using a Snap On diagnostic machine found it was an accelerator voltage problem. I removed the control and I have not had a problem since.
I hope this might be of some help. It was cheap to fix
