Do I need to do a relearn process for the following:
It is a 2006 C6 Corvette. I see sometimes when you change certain things you need a guy with a Tech 2 (or something else to do a relearn). The following items I have changed: 1) camshaft sensor in timing cover; 2) new accelerator pedal assembly; and 3) crankshaft position sensor. All items replaced with GM parts. Not sure if computer relearns itself, I follow some procedure myself (ie. turn car on rev to 4000 rpm and then shut off etc.) or I need somebody to reset with a computer.
thanks - irok
