How did you all run your wideband sensor wire?
Like the title says, I'm installing headers this week with a wideband sensor/gauge. I'm wondering what is the best way to run the wiring from the wideband into the car? Up the tunnel and through the firewall? Or is there a way to bring it in under the console and through the dash?
'11 GS M6 if that makes any difference in what grommets are available, etc.
Thanks!
Thanks!
Thanks!
Thanks!
I just did this last week and i found the best way was to run the power wire from the fuse block under the carpet passenger side and the sensor cable thru the shifter boot...the easiest way to do it
St. Jude Donor '13-'14-'15
Are you using the wideband to run your engine in Closed Loop all the time OR are you simple using the wideband to do testing of your AFR's at WOT ??
If you are using it only for testing I always just run the wires thru the passenger window
If you are using the wideband to run the engine all the time at P/T---I ask WHY ?
What is your thinking that you believe you need a wideband rather than the stock narrowband to run your eng at P/T ??? I see no advantage--- Read the AFR's with your wideband only for testing at WOT ---Re adjust your PE settings in your tune to achieve whatever AFR you want rinse and repeat until you get your desired AFR's
PS----Remember that the only correct AFR readings used to tune in when your car's trans is in a 1:1 ratio OR on an automatic 3rd gear--On a manual trans test the AFR's in the gear that is 1:1 only at WOT----AFR's readings when the trans is OVERDRIVEN are in accurate and always RICH and bounce all over the place---
Most also install a permanent gauge with a wideband O2. Hence the need to route the cable properly.
