First time on a dyno
I had never even been to a dyno much less had my car on one. Went to Izzy Performance in Carson ca yesterday to have Tom work his magic. It was awesome! First of all, I’d imagined a cramped, dirty place with no parking. It was a great facility with ample room.
He had another customer’s super clean c7 z06 on it and it was really neat to watch it all happen before he pulled my c6z on it.
I was there after getting ahp heads and a cam and asked for a safe tune with no care about numbers. I made decent power off the bat and we made some hardware and software changes to make everything just sing.
I really appreciated the shop owner, Izzy, getting me in last-minute as I have the first race on Sunday. It is a top-notch place and knowing my car was in good, highly experienced hands was worth any effort it took to get there. I have a video up on my Instagram page if anyone is curious (can’t put it here): @jfryjfry
It was about 520 hp and 450 lb/ft.
Tom said that there was a little left if we wanted it but because it would be road raced often, he felt it would be better to keep it a touch richer to keep it in the safe side.
Which is nice because that's exactly what I had asked for
frankly I had hoped for a little more but tom said, looking at the airflow nimbers, that the stock air filter housing was probably hurting us by quite a bit.
unfortunately for me, I have to pass ca emissions and anything other than stock would fail the visual.
I passed CA emission with MF103 installed on more than one occasion. Having said that, there's plenty of air intakes that can easily be swapped in and out every 2 years for smog.
I couldn't help but shake my head though at your combo. You NEED to get a CAI. An AirRaid is only $350 and installs in <20min (and can be returned to stock in less time, for smog checks). My car put down more torque than yours without the cam. I only have the AHP heads, AirRaid, and ported TB/intake. You are leaving a LOT on the table and choking up the engine. Recently I did a smog check and put in my stock airbox, and SOTP felt like I had lost 30-40hp as the motor was definitely struggling to breath. I'm surprised Kohle didn't yell at you!
AirRaid+re-tune ASAP and I'd bet you're up around 530hp/475tq.
I'm heading back for a cam/retune in the next month or so.
BigVette427 (06-13-2018)
I know I know… My biggest concern was smog and I did not want to Have to get it re-tuned every two years.
So am I correct in my understanding that going back to the stock intake was seamless and smog was no issue? If that’s the case then I will probably save my pennies and get a proper intake.
Looking at the numbers, Tom definitely felt that the intake was hurting power a bit. And based on numbers like yours and others’, the biggest difference for me and another 30 horse seems to be the intake.
If you're tuned with an aftermarket CAI, you won't have any issues putting the stock airbox back in. No need to be concerned about the car not running right or throwing codes during smog. Computer adjusts the fuel trims accordingly. Only difference is that you'll feel the missing power.
Wipe it down, service the filter...off to the races. https://www.corvetteforum.com/forums...id-intake.html
Tom tuned my car as well, and I agree, great dude!
I'm doing the AHP 116 cam soon - very similar to yours with different lift specs. I'm currently deep in debate about adding a ported MSD intake. I'm getting a bit scared with all the apparent maintenance to that intake as far as bolts coming loose
I'm curious too! And @jfryjfry is DEFINITELY curious!
Supporting Vendor
Received 1,012 Likes
We really like the MSD intake manifold (especially since it now has a CARB #)!!!
We stock and sell our Ported MSD intake manifolds in case anyone is in need on of one.
Regarding the bolts coming loose on the MSD intakes... We have never had any issues with that, make sure to use blue lock tight and toque the bolts to the MSD specified specs in order they list and you should not have issues. If you order our Ported version of the MSD it comes already fully assembled and torqued to spec.
https://www.americanheritageperformance.com/
Feel free to email us HP@americanheritageperformance.com or give us a call @ 310-326-2399 if anyone has any MSD intake related questions.
MTPZ06 (06-13-2018)
Stock cai flows plenty...biggest change is in keeping the IAT down so the comp doesnt pull timing as well as smoothing the maf signal at low speed (Halltech maf forward design). This helps those running maf only tunes keep fueling smooth since maf hates turbulance.
Nice job on the build!
