ECM codes anyone have a thought?
Started with bad #6 coil & wire, fixed that but still this.
Also I get EBCM no comm
Should that be right? I was messing around with tpms and wheel sensors and disconnect swps. All that is put back & sensors are installed and learned and seems ok.
Learning this tech2 so bear with.
Whenever u get the dreaded EBCM no COMM message it is usually a bad connection at the ECM or BCM side ,
pull the fender well inner liner and pull off the connectors off the ECM , clean them with Contact cleaner , dont use anythng else to clean as the solvents might leave a residue or react badly with the metal of the connector
test and see if you have communication, if so clear the codes and see if they come back ..
If u still have no comm hen pull off the BCM side next and do the same ..
these two connectors are usually the problem
as far as your codes , I think the only real one is the EVAP code but you wont know till you clear up the EBCM issues...
Dave
Dave
Dave
Dave
Which inner fender well? This c6z is new to me also. It lived Fla area before socal.
