★ ★ CHUCK CoW HAS HARD to GET 2005 C6 E40 ECMs / PCMs / COMPUTERS ★ GET EM' QUICK!!!
Former Vendor
St. Jude Donor '07-'08-'09-'10-'12-'13-'14
★ ★ ★ ★ CHUCK CoW HAS HARD to GET 2005 C6 E40 COMPUTERS ★ ★ ★ ★
★ ★ ★ ★ ECMs / PCMs / ECUs ★ ★ ★ ★
GET EM' QUICK!
While they last....
• • These Computers are getting IMPOSSIBLE to find.• .•
Yes, you heard right... We have access to those
IMPOSSIBLE to find 2005 C6 Corvette Engine Control
Modules.
These computers are NOT new. They are used modules that have
been sourced from reliable places in LIMITED quantities.
All modules are cleaned, inspected, and have been tested 3 times
back to back with FULL ECU WRITE and READ procedures to verify
communication. Where possible we test them for the popular
failure DTCs
If you've experienced unexpected ENGINE SHUTDOWN,
REDUCED ENGINE POWER, NO STARTS,
DTCs P0601, P0603, P0604, P0606, P0607, P060D,
P060E, P0641, P0651, and / or a multitude of other
unexplained symptoms, or DTC codes that just won't
go away....
Then you just might have a BAD E40
ENGINE CONTROL MODULE.
GM no longer has these modules and the dealer
can no longer get them. Additionally, they are virtually
IMPOSSIBLE to rebuild or repair and prices
are going up quickly.
We will do everything possible to help you diagnose
your bad ECM to be sure you actually need one
BEFORE you order.
If your Corvette is already custom tuned, in most cases
we can recover your tune and transfer your Vin # to
the ECM we provide to make for a much easier repair
process.
Please be sure to properly diagnose your ECM failure
as THERE WILL BE NO 100% REFUNDS.
ALL ECMs come with updated software and / or
copies of your original tunes along with our famous
CoW BOOSTER!
Should you mis-diagnose your failed ECM prior to
ordering our replacement ECM, we will only refund
you 50% of the cost of the ECM less shipping and
any other charges. In other words, we will transfer
your new CoW BOOSTER! and TUNE to your original
ECM so... nobody loses 100%
•ALL CUSTOMERS ARE REQUIRED TO SEND IN AN E40 CORE ECM WITH UNBROKEN PLUGS.•
Prices can vary so PLEASE call us at
914-332-0049
to discuss your particular situation.
Thank you!
Chuck CoW
The dealer can't get them? That doesn't sound good. I had one fail on my last car. I have another 2005 Corvette now...
