C6 Scan & Tune Onboard Diagnostics, Service Advice, Dyno Tuning, and Fuel Management for the Corvette
vitesse controller AND tune?
Old 04-22-2019, 02:59 PM
hmmmm16417
hmmmm16417's Avatar
Default vitesse controller AND tune?
Maybe a stupid question, but I'm going to be getting a tune through diablew soon and have a Vitesse throttle controller that I have never installed. I was curious how many of you still ended up installing one AFTER a tune and if you still see a lot of benefit. I was already informed to at least wait until AFTER to install it if I still think I need it.
Old 04-22-2019, 04:11 PM
theandrewo
theandrewo's Avatar
My car came tuned when I bought it and I installed the Vitesse controller after. Massive difference. I run it on either 4 or 5. (0-9 range)
Old 04-22-2019, 06:17 PM
Timothy H
Timothy H's Avatar
I don't know the correct answer. But it seems to me the tune would take care of the throttle response so no need to have the Vitesse throttle controller. Again I'm no expert.
Old 05-02-2019, 07:37 AM
jim2092
Support Corvetteforum!
jim2092's Avatar
St. Jude Donor '08
In brief, the Vitesse can alter one setting in your Engine Control Module. A tune can alter thousands of settings including that one. Take your choice.
jonjoy (05-06-2019)
Old 05-02-2019, 11:41 AM
Mike@DiabloSport
Supporting Vendor
Mike@DiabloSport's Avatar
But, to be fair, you can't actually adjust the pedal response on the C6 in a tune the way you can on a C7.
Old 05-02-2019, 03:02 PM
jim2092
jim2092's Avatar
St. Jude Donor '08
True. Should have said that the 10+ things that should be changed; torque mngt, etc. will give you the same result and much more. And it will be way better if he has an automatic. You know that but he doesn't.
jonjoy (05-06-2019)
Old 05-02-2019, 03:33 PM
hmmmm16417
hmmmm16417's Avatar
All good info. I do realize the tune make a huge difference and I may not even need the controller. Just figured I'd get some input from those with experience. Wasn't sure if I should waste time installing it after tune or not.
I'm very anxious to he it turned, just need to find the time (already paid lol like a month or two ago)
And yes, A6 auto.
To vitesse controller AND tune?
Quick Reply: vitesse controller AND tune?
