Diablotune questions
If I apply the 93 tune, then go back and do edit parameters and soften up the shifts, does that flash back all of the stock settings when I hit apply except for the TCM settings I modified, or does it only adjust the changed ones? I want the extra power and sooner downshifts, but even on firm instead of hard, the shifts upset the chassis bad. I'm sure it's great at the strip, but not what you want when accelerating out of a bend.
Supporting Vendor
You'd select the TCM Firm Shift preset tune to install, then choose to Modify the TCM tune.. make the changes you want.. and then install the tune.. and that will install the TCM Firm Shift tune with the adjustments you made to it.
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS LS3, short-throw shifter, NPP perf. exhaust, BMR strut-tower brace, Cold Air Inductions cold air intake, catch-can, ported/polished TB, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
Supporting Vendor
