LS3 Street Tune with issues under cruise. Hesitates / misses while cruising @ 1.5K
Hey guys,
So we street tuned my LS3 Grand Sport that has a BTR Stage 4 Cam and Intake.
Basically having issues while cruising. At 1500 rpm I will get a random miss / hesitation ever 5-10 seconds with steady light throttle. I can see my wideband fluctuate radically when this happens. Its pretty annoying and basically its like the car partially and momentarily falls flat on its face then it comes back then it repeats.
Under WOT the car pulls very hard and the AFR on my wideband stays at 12.
What are some things I should take a look at or rule out?
Much appreciated and would love to get this thing dialed in!
Received 1,194 Likes
St. Jude Donor '15
Anything done intake / MAF wise? What do the MAF/VE/Dyn airflow look like? Are they smooth or bouncing around a lot?
Is the hesitation lining up with what fuel trims are doing?
Check plug wires make sure all are seated all the way.
What tranny do you have? (If it's an auto fo you have a stall converter)
An uh that's a big cam which will require a lot of tuning.
If your car is an auto and you are on the stock stall, that cam is way too big.
Cam is probably too big even if it is a manual.
You can get to the same power (or very close) with a smaller cam and the car will be easier to tune and easier to drive.
Basically, I think your big-*** cam is the problem.
BIG CAMSHAFT VS SMALL CAMSHAFT
Hey guys,
