I have had had an ABS/TCS error for a while now. I finally bought a scan tool to read codes. It tells me that the right rear wheel sensor is bad. Oddly, I replaced this same one about 4 years ago.
To run complete diagnostics, my scanner says to put ignition into "ON" mode without the engine running.
I am drawing a blank.
If I hit the button, the engine starts.
Do I need to start it and stall it or is there another way?
Thanks in advance.
Hold the bottom of the start button for about 5 seconds. When you hold this button for a second or so the car will be in accessory mode. When you hold it for longer, the car turns "on" without the engine running.
