by getting the kooks with catted x-pipe instead of the catless x-pipe?Thanks
I was told by several tuners, as well as a very popular header manufacturer (LG), that it's less than 5. Now I'm sure that's relative to what you are doing to the engine, and if you add more cubes, the restriction will hurt you more. Stock displacement, probably not a big deal, as they noted, and you shouldn't have to worry about passing emissions.
thanks 5hp isnt much and emissions is no problem here im just worried about the it being loud
No cats = very loud for sure, of course depending on your exhaust choice! The HP issue is really not an issue though. If it's loud you're worried about, I'd stick with the cats to be a little more safe.
They gained less than a horsepower by taking the cats out. So it comes down to the following:
1) Leaving the cats out saves you $300.
2) Leaving the cats out causes a louder exhaust and a lot of rasp (sounds like a garbage truck)
3) Power wise it's not worth hardly anything
4) Leaving the cats in is good for emmisions and the quality of the air we all breathe.
So spend the $300 and put the cats in, it's worth it for a smoother sound and cleaner air.
Thanks,
Glenn
+5-7 RWHP - Louder - $300 less What's the decision?
