Car is BAD
Old Mar 27, 2006 | 07:07 PM
DSOMC6's Avatar
DSOMC6
Default Car is BAD
Stands for: bent air dam or broken air damn!
Cannot seem to keep from knocking the crap out of the air dam in the front. It has some flexability, but one bump to hard and it's history. Or at least part of it. I dislike these steep driveways in CA! And I am considering loweing another inch up front???
I am sure others suffer from the same if they drive it up or down driveways, over speed bumps etc. What the heck do other auto mfg co's put on the front of their cars that can handle a little abuse?
Old Mar 28, 2006 | 04:34 AM
npm's Avatar
npm
Old Mar 28, 2006 | 04:54 AM
shopdog's Avatar
shopdog
A couple inches more air.
Old Mar 28, 2006 | 10:53 AM
JFTaylor's Avatar
JFTaylor
Cruise-In VI Veteran
Cruise-In VII Veteran
St. Jude Donor '06
Cannot seem to keep from knocking the crap out of the air dam ... steep driveways...loweing another inch up front???
Two Solutions:
1) Raise the front
2) Park on the street
Old Mar 28, 2006 | 12:20 PM
fenderowner's Avatar
fenderowner
I just learned to live with it. I drive in and out at an angle and slowly. By the way, Chevy says the air dam is meant to flex when scrapping on driveways, etc., e.g., page 2-21 of the 06 manual states:
Front Air Dam
Your vehicle is equipped with a front air dam which has
minimal ground clearance.
Under normal operation, the air dam will occasionally
contact some road surfaces (speed bumps, driveway
ramps, etc.). This can be heard inside the vehicle as
a scraping noise. This is normal and does not indicate a
problem.
Use care when approaching bumps or objects on road
surfaces and avoid them when possible.
Maybe you're too eager to get in and out of your driveway!!
Old Mar 28, 2006 | 04:44 PM
w.f.tracy's Avatar
w.f.tracy
I managed to pop the plastic rivets out that hold the air dam in place at the ends of the center piece. Dealer replaced at no charge. No big deal, but my dealer is only three blocks from my office,. and I can go right past it on my way to work. Took just a few minutes
Old Mar 28, 2006 | 05:19 PM
Sinister Evil's Avatar
Sinister Evil
Same thing happens to me in my driveway. I'm still going to lower it.
It was a pleasure meeting with ya at the OC C6 round-up. I took your advice and went with LG LT's instead of the cat-back.
Vic.
Old Mar 28, 2006 | 07:04 PM
corvette pilot's Avatar
0corvette pilot
Former Vendor
you could remove it and trim it to correspond with the amount of lowering, but I would just let it naturally wear down.
Old Mar 28, 2006 | 07:31 PM
Burnt C6's Avatar
Burnt C6
2023 Corvette of the Year Finalist - Unmodified
2022 C5 of the Year Winner - Unmodified
Cruise-In X Veteran
St. Jude Donor '08 thru '11,'22 thru '26
Just wait will the car in front of you clears an object in the road and you run over it. I tagged a dead animal and it took out the air damn along with all the brake ducting and part of the inner finder well. Fortunately it cost less than $150 for the body shop to fix
To Car is BAD
