bilstein shocks install ?
Old Jan 26, 2007 | 08:37 PM
drop top man's Avatar
drop top man
Default bilstein shocks install ?
my shop is installing bilsteins on my c6 .their are sensors on the stock one,s now. their are no connections for the new one,s. is there a way to bypass sensors without having lights comming up on the dash. also will this make the computer in the car go crazy.
Old Jan 26, 2007 | 09:39 PM
torch2000vert's Avatar
torch2000vert
If your car has the F55 option or MRC do not take the stock shocks off! F55 is an expensive option and a very good one as well .Bilsteins would not be an improvement in ride, handling etc. If you do take the MRC shocks off and want to sell them, drop me a PM...
Old Jan 27, 2007 | 03:17 PM
1 slow 97's Avatar
1 slow 97
all they need to do is put a $2 resistor from Radio shack in the shock harnes to fool the computer into thinking the shocks are still hooked up. That worked like a charm when I put bilsteins on my C5 that had the ajustable shock option. Of course by getting rid of the Factory shocks you will not be able to adjust shock settings anymore. You paid good money for that option too bad you want to delete it. But if you track the car the Bilsteins will actually be alot Better.
Old Jan 28, 2007 | 05:09 PM
drop top man
i went to radio shack and they have allot of resistors.will i need to bring the sensor off the shock to see which one fit ?
Old Jan 28, 2007 | 05:34 PM
torch2000vert
I doubt cheating the current version of the F55 will be so easy as guessing what resister to install.The BCM also looks at steering posistion, wheel spin, ABS etc. Your far better off in terms of track performace with the f55 than with anything less of 3K set of coilovers. And even that is debatable...
To bilstein shocks install ?
