tranny noise???
Old Feb 19, 2007 | 11:06 PM
PaulC6Z's Avatar
PaulC6Z
Default tranny noise???
Hey,
Have any of you guys heard a grinding noise in 2nd gear between 2000-3000 rpm. Dealer said that it's not covered by the warranty. I'm a 2006 c6 with 6300 miles M6 tranny. The rear end makes noises at low speeds (2-3mph) while doing dounts. WTF???
Old Feb 20, 2007 | 12:24 AM
c6nut's Avatar
c6nut
I had the same problem in my 05. They said it was normal. Never had a problem with the tranny. Everything else just sucked and they took the car back. am on my 3td one. I guess 3 times a charm.
Old Feb 20, 2007 | 06:53 AM
VET4LES's Avatar
VET4LES
Originally Posted by deuce biglow
Hey,
You need to find a new dealer. The rear end is covered under a TSB and the transmission problem is not normal. I wouldn't mention the donuts.
Old Feb 20, 2007 | 10:36 AM
MSTRBLUE's Avatar
MSTRBLUE
If you here the noise while going in a curve, could be the TSB about swapping out the gear oil in differential. If not, then TSB talks about replacing clutch packs. I had this issue and replacing gear oil in differential solved my problem.
Old Feb 20, 2007 | 11:33 AM
PaulC6Z's Avatar
PaulC6Z
Thanks guys. I'll be going to a different dealer today or tomorrow.
To tranny noise???
