K&N and Free Air Mod Using Toggle Bolts
#41
Ok thanks thats good, i was messing around with it tonite and although i didn't see it mentioned or missed it, it seems apparent that the filter box and bridge must be removed first to be able to 'work' in the area i thought i would be able to open up the shroud with the filter assembly in place, but it's no biggie, thanks again.
You are not removing the shroud, you are simply spreading it open it at the bottom of the shroud! You open up the shroud from underneath the car!!
#42
I'm "Apache" a psycho dog
Hi...you do NOT need to remove the filter box or bridge!!!
You are not removing the shroud, you are simply spreading it open it at the bottom of the shroud! You open up the shroud from underneath the car!! See the below thread to see exactly what you need to do. Its just under the front bumper!!
http://forums.corvetteforum.com/show....php?t=1747569
AHHH, stupid me i thought it opened at the top, this explains alot, so looking at the car from the front the shroud would have to be pulled towards the front of the car?
#43
No...facing front you are pushing the bottom of the shroud underneath the car toward the back of the car. As explained in that thread, you'll need to remove 2 push pins and then with the toggle bolts you "spread/push" the shroud back away from you...about 3". You need to get your head underneath the car with a light to see. Its directly behind the grill underneath the car.
#44
#45
Do not remove your Racemesh, you can much better access it from behind. In essence you are going to lay down on your back and sliding a bit so to get your head underneath and looking up. Its right where the underneath painted facia ends.
#46
Issue with 08 Z51 MN6 oil cooler bracket
Has any one figured out a way to do this mod with an 08 Z51 MN6? I was going to try it this afternoon but the oil cooler bracket is attached to the shroud right next to one of the two push pins.
It looks like if you move the shroud..even on the side away from the oil cooler....the oil cooler is going to hit the radiator.
#47
Edit: I think the problem is that you have Z51 option which has that extra oil cooler & line and is not to be found on the base FE1 C6. Thus, the guys doing the free air mod on the LS3's must not have Z51.
#48
Thanks for posting and the tips, was able to do it today with the help of 60* plus temp's
#50
Anyone with a Z51 or a Z06 done this free air mod?
Any issues doing the free air mod with the Z51 or the Z06 oil cooler, or is the oil cooler in the way?
#51
z51 here would like to do this mod, concern is that , gm engineers are not stupid why is the system sucking warm air to start, the whole front of the car is one big scoop. I do think the car pulls back timing when the enigne and air are hot. so it is a great mod but are the gm vette guys going to leave free hp on the table for no reason? I know a bunch about cars but these guys are better engineers than most will ever hope to be and I know that big companies are comprimise this for that but what gives?
#52
#53
For the guys that have done this mod; have you driven you car in rain with the shroud propped open? Have you checked for water incursion at the filter or past it?
My guess is that chance for hydro lock is non existant unless you are in 2 feet of water, but there is a chance (good chance) of getting the filter wet in a hard rain. What about past the filter?
#56
Rather than toggle bolts, I used rubber bushings left over from my Bilstein install. They work very well, and have a nice, finished look.
This mod works.
#57
St. Jude Donor '08
#59
I just had a kinda hair brained idea, What if you took one of those cold packs for your back/neck and velcroed it to the inside of the air inlet on any cold air system to cool the air....Anyone think it would work. You can freeze them, and i would think that air going across it would definately cool the IAT down... I figure it might help in the summer.
Daren
Daren
#60
C1 of Year Finalist (stock) 2019
2016 C1 of the Year Finalist
2015 C2 of the Year Finalist
Daren
Daren
But hey, give it a try and let us know if it works.
