C6 1/4 Mile Performance Challenge
#6361
Category:LS2 bolt on
1. Your entire profile completed & read Instructions: Yes
2. A copy of your entire time slip posted to the thread as in post # posted below
3. The complete the details of your pass using this template in your post:
4. Year Corvette 2006
5. Type of Trans M6
6. Type of Suspension Base
7. Stock Performance options none
8. Tires utilized NT05R DR 275/40/17
9. Modifications: Cats Deleted, Flowmaster Catback, Tune
10. Dyno numbers if you have them None
11. As much info you may want to add about the run, 4000k launch on stock clutch 58k miles, 17psi at rears 35 psi at fronts, 1/4 tank of gasoline.
12. Typed in the post (as some time slips get deleted & etc after being posted)
___ Name of the Track Edinburg Raceway
___ Date of the pass & weather conditions 11/07/12 Temp 71F
___ 60'.............1.83
___ 330'........... 5.30
___ 660'...........8.115
___ 660’ mph....87.24
___ 1000'.......... -----
___ 1320'..........12.525
___ 1320’ mph….112..09
5. Type of Trans M6
#6362
Category:LS2 power adder
2. A copy of your entire time slip posted to the thread as in post # _____ posted below
4. 2007
5. MN6
8. Hoosier 28" slicks on rear and M&H front runner radials on CCW Drag pack
9. Modifications: UPP Twin Turbo kit @ 10 psi, 4.10 gear, RPS Twin Disc, Fuel system using VP MS109 fuel
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc : FULL WEIGHT NOTHING REMOVED, still have floor matts is and all! Launched at 5500 with a slow clutch release to spool turbos shifting at 6500, front tires 40 psi rear tires 18 psi Crossing the traps on the rev limit every pass! weighed 3250 with me
___ Name of the Track Rockingham Dragway
___ Date of the pass and weather conditions 11/10/12
60' - 1.506
330' - 4.19
660' - 6.435
660' mph - 108.66
1000' - 8.365
1320' - 9.984
mph - 135.44
Video from friends phone
http://www.youtube.com/watch?v=UblHY...L&noredirect=1
4. 2007
5. MN6
60' - 1.506
330' - 4.19
660' - 6.435
660' mph - 108.66
1000' - 8.365
1320' - 9.984
mph - 135.44
#6365
Congrats on the 9s Shoaf!
But I see you make a point to clarify that this was done at "FULL WEIGHT"...I assume that means that you weren't using skinnies during this pass?
#6367
I've been doing a little looking around on here trying to compare my times with some of the other LS MN6 cars and I think I found a mistake in the 2nd place LS2 Power Adder spot! Tekhombre has the #2 spot but his original post shows the car being an A4 (post 1153) and the listing shows is being a MN6???? Just curous if this was a typo or what because if his car is/was an auto then that puts me number one as far as Manual trannys go!
#6369
LS internals
MIR
11-16-12
45 degrees clear
DA -1000??
Norm B.
Category:LS2 internals
2. A copy of your entire time slip posted to the thread as in post # _6299____ posted below
4. Year Corvette 2005 convertible, power top
5. Type of Trans A4
7. Stock Performance options (as in optional gears with the automatic, & etc.) 3.15 Gears were stock(now 3.42 C5 Z06 diff)
8. Tires utilized MT DR 275/40/17 gto w/M&H fronts
9. Modifications: SDPC Ls3 CNC ported heads/L76(ported)231/240 cam. PTB, CAI, LG LTs, Z06 muff, 3.42 gears C5 diff,Yank ss 4000 lightened ...
10. 485/433
11. 3200 launch 6800 shifts
___ Name of the Track MIR
___ Date of the pass & weather conditions 11-16-12 ~45* dry -1000 DA
___ 60'..............1.327
___ 330'............4.075
___ 660'............6.412
___ 660’ mph......105.09
___ 1000'.......... 8.441
___ 1320'..........10.157
___ 1320’ mph….129.43
did run 131.59mph but not on this run
[IMG][/IMG]
[IMG][/IMG]
11-16-12
45 degrees clear
DA -1000??
Norm B.
5. Type of Trans A4
10. 485/433
[IMG][/IMG]
[IMG][/IMG]
#6371
Lucas oil raceway
11-16-12
45 degrees clear
DA -1000??
Norm B.
5. Type of Trans A4
10. 485/433
___ Date of the pass & weather conditions 11-16-12 ~545* dry -1000 DA
[IMG][/IMG]
[IMG][/IMG]
11-16-12
45 degrees clear
DA -1000??
Norm B.
5. Type of Trans A4
10. 485/433
[IMG][/IMG]
[IMG][/IMG]
#6372
Received 2,061 Likes
I'm sure glad someone captured that launch at the perfect time. It's the visual that makes the timeslip all the more impressive than it already is.
Major congrats
Major congrats
#6373
Tommy D will correct it when he sees this I'm sure.
#6374
Lucas oil raceway
11-16-12
45 degrees clear
DA -1000??
Norm B.
5. Type of Trans A4
10. 485/433
11-16-12
45 degrees clear
DA -1000??
Norm B.
5. Type of Trans A4
10. 485/433
The Z06 mufflers were actually still on the car for that pass as well, correct?
#6376
that pass had the "race" mufflers all the way out the back. I ran what would have been a certain 10.18 had I not lifted(as requested by Gary and Rob) on the very first run of the day with my z06 muffs on. It had an identical.1.327-60' and ran .02 slower to the 1/8. 6.43 to my 6.41 of the 10.15 pass.
The suspension on the car is totally bone stock except the front sway bar is removed(9.3 pounds).
I run 20 psi cold in my Hoosiers.
Also to note is that the diff is a bone stock 03 c5 z06 diff I bought used in the c5 for sale section
I'm sure by now I have 300 runs on the car getting it dialed in. I think I ran about 10-12 passes friday
#6377
Former Vendor
Category: LS3 Internal Engine Mods
4. Year Corvette 2008
5. Type of Trans TR6060
7. Stock Performance options (as in optional gears with the automatic, & etc.) Z51
8. Tires utilized 26x11.50x17 MT ET Streets and M&H Fronts
9. Modifications: Tune Time Performance Cam, Heads, ARH, EWP, FAST, CAI, 4.10s
10. Dyno numbers if you have them 475 RWHP (Mustang Dyno)
11. As much info you may want to add about the run, launch techniques, tire air pressure & etc Passenger Seat and Sway Bar Removed, 4200 RPM
___ Name of the Track Maryland International Raceway
___ Date of the pass & weather conditions 11/16/12 Cool, Mostly cloudy
___ 60'.............1.466
___ 330'...........4.308
___ 660'...........6.667
___ 660’ mph....104.42
___ 1000'..........8.684
___ 1320'.........10.374
___ 1320’ mph…133.59
#6378
Hey Guys
Congrats to everyone who posted a new PB.
I am still up to my ears in Sandy recovery mode. I have a bazillion e-mails & etc to get to. I will look to post up all your times later in the week and answer any PMs
Thank you
Tommy
Thank you
Tommy
#6379
